Motor mount help!!!!
Old May 14, 2009 | 11:19 PM
gliderdad's Avatar
gliderdad
I am (or was) building a 390 motor to put in my 66 f250.
The block has only 2 bolt holes for the motor mount, as opposed to the original 352 with 4 bolt holes. The motor mount will not bolt to the block due to the bolt pattern being narrower and set back about 2 inches.
Is there another motor mount that I can use for a 66 250 that will work on this block, or do I have to use another block?
Old Jun 3, 2009 | 06:06 PM
gliderdad's Avatar
gliderdad
Update
The motor mounts that fit the block, and come the closest to bolt size and location, are from a 63-65 390/427 Galaxie.
The bolt placement in the mount is about 1/4" lower than the original truck mount and the block sits about 4" forward of its original position with the Galaxie mounts, so the oil pan will not clear the crossmember.
There is not enough room on the crossmember to move the frame mounts towards the back...so..hard (expensive) lesson learned, an FE block with 2 motor mount holes, instead of 4, will NOT work in a truck without major mods to the brackets that bolt to the frame.
I believe the 2 hole blocks were made from '58-'64 and the 4 hole blocks were '65 and up..just look at the block to verify.
Old Jun 4, 2009 | 12:31 PM
bertha66's Avatar
bertha66
You can make a plate to mount the truck engine mount on that block, I have done this in the past, using a 1/4" steel plate Mounted the plate on the engine and then the truck mount on the plate. Cost at the time I did it was less than $10.
Jobless
15
Jul 10, 2019 06:02 PM
lowtrkn2k
Sep 7, 2012 02:17 PM
nothingbutdarts
Jul 15, 2012 12:25 PM
jav409
Mar 8, 2008 01:46 AM
Nedcampion
Mar 27, 2007 04:49 PM
