302 distributor gear change - Ford Truck Enthusiasts Forums
Old 05-13-2009, 05:18 PM
pipman76 pipman76 is offline
pipman76 is starting off with a positive reputation.
i just bought a 94 roller 302 aod plans for it in my 58 f-100 i was wondering if i could use a older points distributor which would have a electronic conversion in it of course , i need to know if the gear on the 5.0 distributor is interchangable with the older one
Old 05-13-2009, 10:57 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
I'm going to say probably not, you'll have to measure the shaft diameter where the gear mounts to be sure.
Who's running an HEI distributor on 302? Mitchapalooza 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 02-24-2016 04:38 PM
Timing Issue lm987 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 10-19-2015 08:32 PM
coil mount location 1955effie 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 05-11-2012 07:10 PM
302 Distributor compatibility charliehorse Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 6 11-17-2005 02:00 PM
dizzy question! Bulldawg1081 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 8 03-27-2005 01:50 AM
Tags
1983, 302, 360, 58, chang, change, changing, distibitor, distributor, explorer, ford, gear, hio, replace, specs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
