6.9-7.3 head interchangeable?
Old May 10, 2009 | 02:19 PM
F250FarmBoy's Avatar
F250FarmBoy
Are the 6.9/7.3 IDI heads interchangeable?
I ask because I've had a mostly complete '90 7.3L for over 2 years now and I'm gonna scrap all I cant use.
I already plan on keeping the rockers and injectors (to save them for to-be cores for moose injectors hopefully ). Anything else I should keep from the 7.3 thats better than the 6.9 and would swap over?
I would like to keep the heads and tool with them and get them rebuilt later down the road and swap them into my 6.9 when I get a turbo for it.
Thanks
Old May 10, 2009 | 04:34 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
They use two different bolt/stud sizes and thus don't make for good swaps.
-Enjoy
fh : )_~
Old May 10, 2009 | 05:32 PM
F250FarmBoy
Duh.....forgot about that.
Anything else I should keep before I start selling/scraping?
Old May 10, 2009 | 06:32 PM
Festus Hagen
Methanoholic
A list to keep. (Subjective)
  • IP Pump.
  • Injectors.
  • Injector Lines.
  • All thermal sensors and switches.
  • Glow Controller.
  • Lift pump.
  • Fuel line from Lift to Filter.
  • Fuel line from Filter to IP.
  • Filter Head.
  • Rocker Assemblies.
  • Push Rods. (Id'd to the rockers)
  • Vacuum pump.
  • Water Pump.
  • CDR
And the Short list..
  • Everything thats not JUNK...
Personally, I would use the Short List!
-Enjoy
fh : )_~
Last edited by Festus Hagen; May 10, 2009 at 06:34 PM. Reason: Added a couple items
Old May 10, 2009 | 11:00 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Cam shaft, crank shaft and connecting rods are also interchangable as well as the lifters.
About the only thing you can't swap is the heads, but the valves and valve springs can be swapped.
You would have to bore the 6.9 110 thousandths, then you could even use the pistons.
Old May 12, 2009 | 03:29 PM
F250FarmBoy
Well, I guess I should have said which parts off the 7.3 are better than the 6.9 that I could use, like the rockers for example. Are the valves, springs etc, better?
There's no IP/hard lines, filter head, acc brackets. Actually, I have a few pics in my gallery from when I first bought the motor so maybe they can help show what I got....or dont.
The cam is grooved from the fuel pump lever.
I wouldnt put the block in my truck just because I dont know the history of the motor, mileage, additives, etc.
I'm just asking which parts I would benefit from off the 7.3 into my 6.9. And sell the rest, its taking up some space I would like to have.
Old May 12, 2009 | 10:03 PM
Dave Sponaugle
The 7.3 rockers are a big upgrade, bolt right on the 6.9 heads.
The valve springs are probably tired, so no real help there unless they are even weaker on the 6.9.
7.3 turbo valves are an upgrade for the 6.9, even more since you are running a turbo.
Sounds like the cam is well worn and the motor has a fair amount of miles on it.
Lifters are probably about shot with that many miles on them also.
If it were me, I would keep the exhaust manifolds, they do crack and are hard to find.
I would keep and install the rockers.
Oil cooler may be worth keeping, it's not that big.
Oil and temp sensors, tach sensor if it has one.
Fan clutch if it is good.
The rest, well it does take up a lot of room.
OrFordGuy
24
Jan 24, 2011 12:41 PM
1980 Ford F-250
Nov 22, 2010 07:47 PM
Pele
33
Jan 27, 2007 02:42 AM
RollinHi95
Apr 28, 2005 01:51 PM
