1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Drain hole in V10 muffler?
Old 05-09-2009, 02:22 PM
mwsF250's Avatar
mwsF250
mwsF250 is offline
I had the truck idling on a steeper slope the other day and noticed condensation water dripping out of the back of the muffler. Right above the seam at the bottom rear is a hole.
Is there supposed to be a drain hole there, or is it starting to rust through?
It is a '99 with 150K....
Old 05-09-2009, 03:35 PM
Fordfanatic4life's Avatar
Fordfanatic4life
Fordfanatic4life is offline
think its a drain hole for that exact reason...
Old 05-09-2009, 04:31 PM
Furian's Avatar
Furian
Furian is offline
You Keep What You Kill
The engineers at Ford call that a "tinkle hole"...
Old 05-09-2009, 07:19 PM
ken kenmnedy's Avatar
ken kenmnedy
ken kenmnedy is offline
yup theres one in my03 as long as its draining its ok
Old 05-10-2009, 09:42 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
The byproducts of the catalytic converter include water. And it condenses in the colder muffler.
Yeah, there's a drain hole
Old 05-10-2009, 03:17 PM
dstig1's Avatar
dstig1
dstig1 is offline
It's even more basic than that. The output of hydrocarbon combustion from any engine is CO2 and H2O, with other things thrown in (like CO and NOx and unburned hydrocarbons) as the process is never perfect or always right at stoichiometric ratios. The cat is to help that process get more towards perfect by cleaning up the "mess" downstream of the engine.
The drain hole is to prevent water from building up in there and causing corrosion, especially when it is cooler out and the water condenses in the muffler.
Old 05-10-2009, 03:22 PM
EXv10's Avatar
EXv10
EXv10 is offline
It's mainly to prevent the muffler from corroding. They have been putting those holes in there since they invented the cat.
Old 05-12-2009, 11:12 AM
mwsF250's Avatar
mwsF250
mwsF250 is offline
Thanks guys. I've never noticed any of my other vehicles tinkling, but this is the first time I've seen a muffler mounted on it's side with the outlet on top. Definitely an arrangement that will accumulate water.
Of course, now I have to question why the tinkle hole is on the UPHILL end of the muffler. These trucks all seem to come from the factory with the rear higher than the front. The front of the muffler will still hold plenty of water unless parked uphill on a pretty steep slope....
Old 05-12-2009, 02:57 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
I'd think the drain hole needs to be baffled. If it was in front, it would let out unbaffled exhaust, wouldn't it?
Old 05-12-2009, 09:20 PM
EXv10's Avatar
EXv10
EXv10 is offline
I think they are all in the back because of the direction of flow and the hole is so small that it doesn't contribute to any noise or fume problems.
Shernius
Exhaust Systems
07-28-2014 07:42 AM
aquaman
2004 - 2008 F150
02-28-2014 02:31 PM
1990inline6
13
02-26-2014 09:01 PM
Tawn
05-07-2012 10:54 PM
myrangertruck
1983 - 2012 Ranger & B-Series
08-12-2003 07:20 AM
Quick Reply: Drain hole in V10 muffler?
