I posted this in the 73-79 forum but thought it should go here.
I have a 78 F150 460/4x4 with a 9" rear w/3.50 gears. I have a small crack in the axle housing where the carrier bolts on so I want to replace the axle tube. I put in a mini spool, replaced the pinion seal and axle bearings, and a few other things so I don't want a whole rear end. My questions are:
Are all the axle tubes the same for the 9" in the 73-79 era?
Does it matter if I have 28 or 31 spline axles?
Are the axle bearings the same size?
[updated:LAST EDITED ON 19-Sep-02 AT 12:47 PM (EST)]Is the crack in the 3rd member or the case? If the case is cracked why not replace just the case? You want to replace place the axle tubes? I don't get. More information please.
1979 F350,4x4,NP435,5:13 gears,Detroit locker in rear with hardened shafts,ABR in the front,L&L Ladder Bars,360 with 428 crank & rods,390 HP heads,Centerforce Dual Friction Clutch,MSD Ignition,39.5x18 Boggers,bucket seats out of a Lightning,& a Southern Body that is perfect.
1997 F350 PowerStroke 4X4,36 Inch Super Swampers, Strait Piped, Chiped, Propane Injected, LUK Clutch
Sorry. My book calls it the axle housing but some refer to it as an axle tube or case. The crack is in the case/housing/tube between two of the studs that hold the 3rd member on. It extends down below the level of fluid and drips a drop every few weeks. I'm afraid it might get worse when I pound the heck out of the truck on the trails.
