customer access wires under dash/hood ?
I noticed some wires under the dash that have a label on them, something like customer access IIRC. Then there are some wires under the hood on the driver's side that appear to be the same color combos. I tried to search last night and this morning but haven't found anything. I read the owner's manual and no luck there. What I need is a hot wire and a hot in run to power the heat function on the seats I purchased and was curious if any of these would work? It got late and dark last night so I didn't test any of them, but still curious of their purpose. Why are they there? I know I've seen something about them on here but I just can't find it now.
Thanks all
Thanks all
They are there to save you a little time and not have to drill a hole in the firewall to run your own wires for any accessories. Look right behind your power dist box and there will be a few wires with shrink wrap on the ends. They are pretty good sized wires and I use mine for my GP LED and a few other things. I have a 12v constant running through one as well, fused of course, and its fine. I dont know how thick a gauge you need to run a heater though...
on my '00 they were originally labeled "customer use for aftermarket equipment". The manual I had somewhere used to state they were for the trailer brake hook-up since you'll notice that the colors relate to blue brake, red +12. black ground, and whatever white is. they also end about where most people put the brake controller. Otherwise they are just 22 ga wires that go through a bulkhead connector and are sealed to the elements like everybody else said.
Trash Hauler
6.7L Power Stroke Diesel
03-03-2015 06:44 PM
