Simple Fuel Filter Change Goes Bad, Help
So I'm doing just like Guzzle's directions say, I'm cleaning out the bottom of the fuel bowl, Oops... I broke a thin little wire off of a plate an inch or so off the bottom. I'm assuming it's the fuel heater, though it looks different than the one in Guzzles directions, maybe because mine is a late 99 and his probably newer. Is this a very bad thing? I know it's not good, but is it going to do any harm, or just not work? And if that's the case do I need it in the summer? Is there an upgrade I can do? Is this going to be expensive? You all have cost me a lot of money already, all of these mods ie. in tank mod, guages, DP tuner (on order, just before I read about RiffRaffs sale!) Warn Hubs, the list goes on and it's not my fault. I hold you all responsible, now I would like a bail-out please, (my truck is too big to fail) . After all I deserve these things, yeah, I have a right to them!
Sorry my entitlement mentality came out while I wasn't looking. Now I will let the American mentality take over. I'm grateful for all the help and advice offered so freely here, I thank God for blessing me with health, a wonderful family, and the resources He allows me to do things like this wiyh. I'm touched by all of the selflessness I see demonstrated here, not only in advice and actually going somewhere to help people you don't even know (all with no apparent thought of return), but the sincere compasion, when someone is having health problems, or towards the family of a member who has passed away, or someone trying to adopt a child, or... the list goes on, and I'm sure you know of some of the examples I've mentioned. It's things like this that give me hope for America.
Sorry didn't intend to chase that rabbit. Anyway, while I was at it (the fuel filter, not the rabbit) I noticed quite a bit of oil in the valley, HPOP? Or could it just as easily be something else? Thanks again, I don't know if or how to do the sig so,
Howard, 99.5 F350, CC, Dually, and a few mods.
Unplug it. Don't need it. They could short out and cause more problems anyways. If it shorts it will pop the fuse that your PCM(think it was the PCM) is running through. Mine looked good so i left mine plugged in and wired up. But when the time comes it is getting unplugged and tossed.
The hard part is finding that oil leak in the valley. I hate leaks and trying to track them down. A little leak can sometimes turn into a major leak. If it is a little leak, Those kind of suck. Have to wipe everything down and clean it. Then keep an eye on it with the help of rags to find it. Under the turbo/hpop and its hoses/port plugs. etc..
O yea.. Because of FTE i am in the hole as well. The money Mod pit hole. Not like some on here mine are simple but never the less $100 here, $100 there and !,000's to go.. I was running fine. Read through this site and seen all the mods and that was were i got into trouble.. But now the truck is running super.. My DP is next.
You read the the side effects of that stuff? WOW. Careful with that stuff my friend.
Side effects
The most commonly reported effects include constipation, fatigue, dizziness, nausea, lightheadedness, headache, dry mouth,anxiety, pruritus, and diaphoresis. It has also claimed to cause dimness in vision due to miosis. Some patients have also experienced loss of appetite, nervousness, anxiety, euphoria, abdominal pain, diarrhea, dyspnea, and hiccups, although these symptoms appear in less than 5% of patients taking oxycodone. Rarely, the drug can cause impotence, enlarged prostate gland, and decreased testosterone secretion.In high doses, overdoses, or in patients not tolerant to opiates, oxycodone can cause shallow breathing, bradycardia, cold, clammy skin, apnea, hypotension, pupil constriction, circulatory collapse, respiratory arrest, and death.
Side effects
I had to do some running around so I put it back together, seemed ok. I guess I'll take it apart again and unplug it. Is the purpose of it to help cold starts? I have trouble when it's at all cold with the "romps", sometimes it is several attempts before it will even stay running. Fresh oil, new glowplugs and that heavy duty (Stancor?) GPR, nothing has fixed it. I would hate to add to the problem. As always, thanks for the help.
JPs2003
10-03-2010 11:55 AM
