Timing pointer
Old Apr 28, 2009 | 06:08 PM
Slyreaper's Avatar
Slyreaper
Timing pointer
Hey guys. I need to set the timing on my truck but i cant see the marks from any where unless im laying under the truck. any tips? also i found the marks but cant find pointer. If any one has pics that would be awesome.
Old Apr 28, 2009 | 08:01 PM
Slyreaper's Avatar
Slyreaper
found it. Rusted over. couldn't see it in the daylight. my bad.
Old Apr 28, 2009 | 09:01 PM
forum155pl's Avatar
forum155pl
pretty stupid place they put it huh?
Old Apr 28, 2009 | 09:08 PM
Slyreaper's Avatar
Slyreaper
Ya, but at least the fan blade only hit my finger once and my timing light 3 times. Im having a major problem using the light though. My ignition system is upgraded and there is a lot of interference. so the timing light is basically a flashlight. Now im just doing it by feel. Im still not sure what i should set the timing on now becasue im running a 4bbl and performance ignition. stock setting is 8 btdc.
Old Apr 28, 2009 | 09:11 PM
forum155pl's Avatar
forum155pl
i have mine set at 10* with 4BBl and MSD dizzy, runs outstanding.. make sure you pull the clip that you use for the timing light #1 wire away from other spark plug wires..
Old Apr 28, 2009 | 09:24 PM
Slyreaper's Avatar
Slyreaper
it may just be that its the cheapest timing light i can find. 15bucks at harbor freight. what I was trying was to just hold the clip in the vicinity above the wire until it flashed slower... that did not really work. I tried to set it at 10 btdc while doing this but when i took it for a ride it was pretty bad. I may have just been getting too much signal from the other wires. ( im running 9mm ford racing wires)
Old Apr 28, 2009 | 09:28 PM
flamebuster's Avatar
flamebuster
You can advance the timing 1 degree for every 2,000 ft. above sea level..to compensate for the altitude...
Old Apr 28, 2009 | 09:31 PM
Slyreaper's Avatar
Slyreaper
Thanks! I did not know that.
Old Apr 29, 2009 | 08:33 AM
uncle.stosh's Avatar
uncle.stosh
Did you remove the spout connector if you have one, or the vacuum line from the distributor before setting the base timing?
10 degrees BTDC is do-able in nearly every engine I've ever owned.
Old Apr 29, 2009 | 08:14 PM
Slyreaper's Avatar
Slyreaper
ya i pulled and plunged the vac advance hose. but i didn't plug the actual advancer on the distributor.
One more question. When i went to look at my marks, some one had marked tdc with white paint. why would they mark tdc instead of where it needed to be ( 8 btdc) ? i think some one had my engine timed to tdc.
Old Apr 29, 2009 | 08:23 PM
flamebuster
possibly marked it tdc for setting the lifters.
Old Apr 29, 2009 | 08:31 PM
uncle.stosh
Sounds like my harmonic balancer. There is only one notch in it and a stupid round hole as a pointer.
It is impossible to shine a timing light into the hole because the alternator is right in the way. I had to time it by ear and guestimate where I'm at BTDC.
Old Apr 29, 2009 | 08:45 PM
Slyreaper's Avatar
Slyreaper
Could be but i don't think my lifters are adjustable. that's a possibility though.
Thats the exact problem i had. I though that hole ( mine has a bolt in it) was the pointer at first. but then i looked past the inner part of the upper radiator hose between the water pump and the air pump and i was able to see the pointer with a flashlight. Maby you have one too but just cant see it from the angles your looking from. I can take a pic if you want.
Old Apr 29, 2009 | 09:05 PM
uncle.stosh
No worries. I timed it by ear last time and it's all good.
Only problem now is that I have a blown head gasket. I'm working on swapping in the 300 six from my other truck.
Old Apr 29, 2009 | 09:15 PM
Slyreaper's Avatar
Slyreaper
why a 6? there should be a 534 some where around here you can squeak in there.
78Ranger400
Apr 21, 2011 04:22 PM
blkempinc
Feb 14, 2010 08:30 AM
apb
Oct 15, 2009 09:36 PM
flipklos
Feb 23, 2009 10:17 PM
Bryan Crawford
1983 - 2012 Ranger & B-Series
Jul 13, 1999 07:48 PM
