rearend id
Old Oct 22, 2002 | 06:46 PM
78bigblock's Avatar
78bigblock
rearend id
I have a 78 shortbox 2wd with a 429 (originally a 400) C6, and what i think is the original rearend with 2.72:1 gears. I want 4.11 or 4.56 and need to know if my rearend is a 9 inch or not. I have the original tag but some numbers are to beaten to read, the ones I can read are ?017 av 4f4 ???? 9(i think) 318a. If this is any help???!!! Any help is appreciated!
Old Oct 22, 2002 | 09:09 PM
Ford79's Avatar
Ford79
rearend id
Does the rear end have a center section that is bolted to the housing in the front? Does it have a rear cover that is bolted on? If you answer yes to the 1st question and no to the second, you most likely have a 9" rear, which is what should be in the truck. I believe that's what the "9" on your tag refers to as well.
Old Oct 22, 2002 | 10:04 PM
78bigblock's Avatar
78bigblock
rearend id
yes it does bolt on in the front, no there is no removeable cover on the back and i thought that was what the 9 stood for, but i was not totally sure. thanx for your help.
Old Oct 25, 2002 | 10:38 PM
bronco351's Avatar
bronco351
rearend id
From the tag i would say you have 3:18 gears!
Old Oct 26, 2002 | 12:33 AM
charlez's Avatar
charlez
rearend id
royleexx
Oct 1, 2019 02:04 PM
Alter Ego
26
Mar 22, 2009 10:42 AM
fifty2f1
Oct 30, 2006 10:10 AM
78bigblock
Oct 28, 2002 09:17 PM
Kamikazee
Apr 19, 2002 06:38 PM
