300 engine build plans
Old May 1, 2009 | 08:25 PM
Harte3's Avatar
Harte3
Best do the Chebby rocker swap or the cam but not both. If you want more lift do it with the cam and check with the supplier to make sure the cam is computer friendly. Decking the block is usually for reducing the squish/quench area plus it does give a cr increase.
Old May 1, 2009 | 09:15 PM
9.ford.5's Avatar
9.ford.5
yeah i was thinking about 1.7 rollar rockers instead of the chevy rockers i will probably not be doin a turbo ill just squeeze as much as i can out of this and call it good
i wanted to bore it .030 over for more TQ and the flat top pistons for compression and clean/ resurface everything then back cut the intake valves 30* grind the crank and throw a mild cam into it along with replacing any worn parts/ bearings then a good tune up and set timing to 12*
Fordidipower
Sep 22, 2013 12:19 AM
Ironman03R
27
Mar 29, 2009 11:05 AM
mattri
39
Dec 31, 2007 12:13 PM
MudinMan19704x4
Sep 5, 2004 06:15 PM
