Damper spacer
Old Apr 24, 2009 | 07:42 AM
bishop0179's Avatar
bishop0179
Damper spacer
I'm tearing down a 390 for a rebuild , just something to tinker on and eventually drop in my '74 250 .
I removed the main pully , balancer and key , but for the life of me I cant get the darn spacer that goes through the timing cover to come off! It moves forward ( to the front ) about one inch then wont budge!
All my manuals and previous experience with this sort of thing tell me they normally just slide off the crank , this thing wont move! in fact, if I get a good grip on it I can turn the engine over!
Any advice is greatly appreciated, I'm thinking I may just have to take it to a machine shop, hopefully the crank will survive
I have some hi-res pics if anyone wants to see them. I did manage to remove the crank from the engine with no further issues ( save a REALLY stubborn #5 main cap , darn rear main seals! ), as the timing chain was sloppy like a huffy bike and I got it off the cam gear
Thanks again!
Old Apr 24, 2009 | 11:24 AM
bishop0179's Avatar
bishop0179
Quick clarification , its the crankshaft damper spacer. Below is a pic of the part, off the crank.
Thanks again!
Blue Thunder Crankshaft Damper Spacers
Old Apr 24, 2009 | 11:34 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Use a muffler clamp! No really it works, just clamp it on the spacer and then use you puller on that.
Josh
Old Apr 24, 2009 | 12:07 PM
bishop0179's Avatar
bishop0179
Josh
That's an idea! Do these things typically get stuck like this ? I've got a heavy duty gear puller as well as a balancer puller .
What kind of muffler clamp?
Thanks a lot!
Old Apr 24, 2009 | 02:45 PM
Bullitt390's Avatar
Bullitt390
The U bolt style, crank it on there as tight as it will go and latch the jaws of puller on there and crank away.
Josh
Xclimation
Jul 22, 2011 10:54 AM
bishop0179
Apr 26, 2009 12:15 AM
jamies460
Aug 28, 2006 04:56 AM
Rico82nd
13
Oct 28, 2003 08:01 PM
texlex
Sep 23, 2002 06:21 PM
