Anyone Know Rotor Thickness Specs for 06 Escape?
We have an 06 Escape Limited and this thing has gone through brakes like water. The dealer says the brake pads are done and we need new rotors. Does anyone know the mininum rotor thickness specs of the Escape ?, I know it is stamped into the back of the rotor but that means I have to remove them to read it. I just want to compare our rotor thickness to what the dealer is saying. I think they are B.S.ing us.
The Escape got new brakes and rotor before we bought it , just prior to 17,000 kilometre mark in the fall of 2006. In the summer of 2007 at 29,000 kilometres they told us it needed new pads and they turned the rotors. Now they are saying it needs new pads and rotors at 45,000 kilometres . Something just doesn't add up here.
Thanks for any replies on this.
per the 2006 Escape Service Manual:
FRONT:
Brake pad minimum thickness 3.0 mm (0.118 inch)
Brake pad maximum taper wear (in any direction) 3.0 mm (0.118 inch)
Brake disc minimum thickness (disc-drum system) 22 mm (0.866 inch)
Brake disc minimum thickness (4-wheel disc brake system) 24 mm (0.944 inch)
REAR:
Brake Pad
Brake Disc
Brake disc minimum thickness 11.0 mm (0.433 inch)
FRONT:
REAR:
Brake Pad
Brake Disc
DoctorCad... you're right there! I just did the front brakes on my 2005 Escape this weekend, I have almost 50,000 miles on the vehicle and the original brakes. I took the rotors to be turned and they were concerned because after turning the first rotor it was 2/1000's under spec and the second rotor was 3/1000's under spec... I told them I wasn't because we're just splitting hairs. It's not like the old days when rotors had some "meat" to them. Next weekend I'm doing the back brakes... drums... a bit of a pain but a lot cheaper than taking it in to a shop.
Oz Econoline
12-19-2015 05:35 PM
Johno.h
10-02-2015 07:43 PM
