Hard start 40 farenheit
When you turn the key switch to "on" you should have a "Wait to Start" light come on. How long does that stay on? It should be on for around 10secs. After it goes out you should hear a relay clicking. It is then time to try to start the truck.
If the WTS light only stays on fo a few seconds then you probably need new glowplugs.
Also there is a super page on here just for your type of diesel engine. If you scroll down the main forum page from here you will come to the Diesel Section. Then look for the Pre- Power Stroke page and post any diesel questions there. Great guys on there who will be able to give you more help. Good luck.
First thing to do is test all the glowplugs and replace any that are bad. Even one bad plug will reduce the time the plugs will be on. You can check them with a multimeter set to resistance. Pull the wire off and check that you a reading between the wire connector and ground. Replace any that are bad. Replace ONLY with Motorcraft or Beru plugs, nothing else.
For testing the relay and controller you will have to go to the Pre-Power Stroke diesel page and get the information there. However if you can hear the relay clicking it should be OK.
I would think your problem is bad glowplugs.
With two glowplugs out the others will only stay on for a few seconds. You need to fit two new plugs. Then they should stay on for about 10 seconds before you hear the relay clicking a few times if you don`t start it righ away.
Replace the two bad plugs and only use Motorcraft or Beru plugs.
When I conect two bolts together on glow plug relay then i have light when ignition is on on glow wire and ground on bateryi think i take pice wire from glow plug relay thru inside the cab and ground and i install some switch before im starting ignition on i been hold this switch for 10 seconds and start
Good idea. Make sure you use a push button switch so that it can not be left ON by mistake.
If you go to the diesel page and do a search you should find a wiring diagram for a switch or ask on that page and I am sure someone will post a diagram for you.
Once you get this problem fixed you will love the truck.
YEs im install manual switch its still the same hard start and also I now some plugs is bad two bad one broken im tested with light tester is some other test for glow plug.Im tested hot wire on battery and other on tip glow plugs when light tester flashing I think is good.Fuel heater is install on this truck
