i personally wouldnt use it. Ive used it in gas engines and its worked ok. But sometimes it has made the oil goopy. Im sure someone else will chime in but i would not recommend it.
No.
It's a bandaid at best for a gaping wound on a gas engine with only 150 psi compression.
A diesel is 400 psi at atmospheric pressure.
Now add 20 psi of boost and compress that by 17:1.
Perhaps a good product for a dishonest used car salesman, nothing more.
No.
. Perhaps a good product for a dishonest used car salesman, nothing more.
Dan, I didn't see your comment at first. Made my day right there! The old motor honey or sawdust in the crankcase trick.
Adding a couple of quarts of gear oil to you engine oil, will achieve the same results as Engine Restorerbs. Thats pretty much all it is, just like Kwik said, bandaid.
