2013 Ford F-150 Error Code P012D
Old 11-16-2017, 12:13 PM
Jonesy0027's Avatar
Jonesy0027
Jonesy0027 is offline
Howdy fellas,
Noticed my service engine light was on. Took it to Autozone and they found error code P012D Turbocharger Inlet Pressure Sensor was bad. Ordered a new one for $37. I'll change out the bad sensor for the new sensor.
Question: How does the error code get reset?
Any input is greatly appreciated. Thanks.
Old 11-17-2017, 10:25 AM
390Ranchero's Avatar
390Ranchero
390Ranchero is offline
You can do one of three things. You can drive it and let the truck reset it itself bit that could take up to 1000 miles, You can disconnect the positive (red) battery cable the keeping it well clear of the battery jumper it to ground, or 3 use a scan tool to clear the code.
Old 11-17-2017, 03:56 PM
fastback89's Avatar
fastback89
fastback89 is offline
Drive on the highway at around 54 mph for more than 10 miles should run most of the monitors. That way you'll know if it's actually fixed.
Old 11-18-2017, 05:53 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
NEVER DO THAT!!! Disconnect the NEGATIVE cable first... it's a personal safety issue.
Old 11-20-2017, 12:29 AM
390Ranchero
You are correct because of possibly arcing with the wrench.
But as an electronics tech we are taught to remove the hot side and leave all grounds connected, then short the positive to ground through a resistor.. This will help drain any capacitors.
Old 11-20-2017, 06:32 AM
projectSHO89
I'm also trained as an electronics tech (40 years). Automotive stuff sometimes has exceptions to the normal bench electronics procedures, this is one of them.
Old 11-21-2017, 03:11 PM
Jonesy0027's Avatar
Jonesy0027
Issue has been resolved!
Replaced the sensor($37) and had Autozone reset the error code.
All is back to normal.
Thanks fellas.
Old 11-22-2017, 01:25 PM
Olytlr's Avatar
Olytlr
Olytlr is offline
Did someone at Autozone actually help you with the code reader? Most will loan you the reader but won't hook it up or clear codes for you due to liability reasons.
And yes, definitely disconnect the negative first and put it back on last. Also, I don't think a KAM reset will clear a DTC.
Old 11-25-2017, 07:48 AM
Jonesy0027's Avatar
Jonesy0027
The Autozone guy reset the code for me. Its been a week now and all is well!
Adakar
1997 - 2003 F150
05-01-2014 05:32 PM
tim_30043
Modular V8 (4.6L, 5.4L)
12-20-2012 02:20 AM
svtrich
07-20-2008 12:10 PM
apollo95
1983 - 2012 Ranger & B-Series
10-25-2006 10:11 PM
ken8769us
1997-2006 Expedition & Navigator
01-18-2006 08:19 AM
Quick Reply: 2013 Ford F-150 Error Code P012D
