Sandblasting Frame POR15 vs Powder Coating
  #31
Old 04-15-2009, 09:40 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
Originally Posted by TxF100 View Post
I was hoping that blasting would make easy work of the undercoating. Some of the under coating is really on there and a bit tar like. How if I go the DYI route do I get this stuff off?
FYI We are in shorts here... Mid 70's great for painting.
a couple good days soaking in the Texas summer sun, and then good scraper, small pry bar and hammer and lots of patience..
Sam
  #32
Old 04-16-2009, 10:14 PM
woodyf1's Avatar
woodyf1
woodyf1 is offline
woodyf1 is starting off with a positive reputation.
well i used chassis saver after sandblasting it worked good however keep in mind it has no uv protection thats what keeps it soft i think anyway I had my frame out all last summer and had to recoat but it is easy to use and looks good Tip1 use the rubber gloves and a respirator of course that paint took 6 days to come off
  #33
Old 04-18-2009, 11:08 AM
bassn1's Avatar
bassn1
bassn1 is offline
bassn1 is starting off with a positive reputation.
I used a wire wheel, Eastwoods and Rustolem for a topcoat. Now if I get chips a $4.00 rattle can will keep it looking good.
  #34
Old 04-18-2009, 12:23 PM
LEckart's Avatar
LEckart
LEckart is offline
LEckart is starting off with a positive reputation.
I have only powdercoated one frame and suspension parts, a 34 Ford coupe. I will not powercoat a frame again for the reasons stated in the previous threads; it is hard and will chip and repairs never look that good. I think powercoating is fine for some things, just not a frame that will be on the road unless you call being on a trailer on the road.
  #35
Old 04-18-2009, 01:24 PM
TxF100's Avatar
TxF100
TxF100 is offline
TxF100 is gaining momentum as a positive member of FTE.
Rustolem does not fade over time?
Zazoos
99
04-26-2019 07:17 PM
3twinridges
07-19-2017 08:02 AM
460harris
02-20-2016 11:20 PM
scottmorgan1309
02-09-2016 07:01 AM
6863m
04-22-2011 10:55 PM
Quick Reply: Sandblasting Frame POR15 vs Powder Coating
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
