Cam timing 5.4
Cam timing 5.4
Just traded for 97 f250 previous owner thinks it has a bent value in one cly. I tested compression and got a 0 in one. Went and got got a junk yard head to put on it. Had it surfaced but didn't do whole a valve job. Got a new gasket and head bolts.
1st question is these the right tools for the job?
eBay Motors: OTC 6498 Ford V-8 Automotive CAM Service Tool Kit OTC (item 120399285694 end time Apr-28-09 17:00:49 PDT)
2nd question
Although I haven't read up on it yet a friend said not only do I need special tools to do the job (see above) but that there is 2 different versions of the 5.4L and the cam timing steps are not the same. So
A. Is there two versions of the 5.4?
B. if yes How to tell which is which to follow right procedure?
3rd question
it looks to me like it will be easier to pull the head from wheel well then from above? Anybody ever tried this route?
97 F250 (LD) 4X4 7 lug ext 3 door cab lariet
2nd question
3rd question
I didn't pull the head, Couldn't find one a "pick a part" so had to go more expensive place they pull and your not allowed in the yard. I just told them 97 f250 5.4 and I assume that's what they gave me. Where would the stamp be? I'm picking up head this afternoon from machine shop.
PS I think I posted wrong tool kit in post 1. Pretty sure this is the one I need but not 100%
eBay Motors: OTC 6487 Ford CAM Timing Service Tool Set (item 250392192876 end time Apr-17-09 16:11:15 PDT)
