Truck missing on idle.
I have a 2002 F -150 XL 4.6Liter triton motor. I went to leave in it this evening and when i crunk it it is missing on idle. If you stick it in gear it really gets to missing bad and when you try and take off it is if you dont have all the power. Any suggestions.
Thanks
John
Thanks
John
I had a very similar sounding thing which is referenced here:
https://www.ford-trucks.com/forums/8...e-changed.html
What it comes down to is that I changed all my spark plugs and bought 8 new COP's for $80 on ebay. They are cheapo's, but to get OEM ones are almost $100 EACH. Needing 8 is super pricey. I think we have pretty much the same engine, mine is a 2003. Give it time, I bet you'll get an error code soon.
Bunggo
Bunggo
Okay thanks everyone for there help. It did not have any error codes at all. It was bad plugs and one bad cop also i dont know what it is call but its inside the tube where the air fliter goes its that sensor it was dirty and they took a cuetip and some carb cleaner and cleaned the i think its called the air sensor. Tk runs awesome. Changed those out and walla. Runs like a singer sewing machine. Now i got another problem went to come home this eveing and truck acts like trans is slipping. When you get on a pull up a hill in overdrive truck starts vibrating and acts like it is missing. I just had fluid and flilter changed on tranny.
Thanks for all the info, Bunggo. A good friend of mine owns his shop and had one of those computer that you hook to the truck and it reads out everything including fuel and all. He drove it around the block and the computer thing read it out. Thats how we found it. Now more problems though. Just my luck.
[quote=Bunggo;7384599]I had a very similar sounding thing which is referenced here:
Just for future reference:
Our new Ford COP’s, the Sultans of Spark(S.O.S.), have
been designed with both durability and performance in mind.
Please see them at:
http://www.performancedistributors.com/soscoils.htm
Quality was the main feature we stressed when we went to the
drawing board on these coils.
By the way, for those of you who only need to replace a defective coil,
our SOS Coils are available separately.
Please see them at:
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
FTE Sponsor
