Is this true? - Ford Truck Enthusiasts Forums
Is this true?
Old 04-11-2009, 06:25 PM
dethomson
dethomson is offline
dethomson is starting off with a positive reputation.
Is this true?
I saw NumberDummy post this in another forum and wonder if my A/C is toast.
"The A/C may not be any good....if any of the hoses have been removed, if any parts have been removed where freon is a factor.
Once outside air gets into the compressor, condenser, dryer tank or expansion valve, the entire system has to be evacuated within several weeks...otherwise you can kiss these parts goodbye."
I rebuilt my truck 15 years ago and never charged the A/C after putting everything back together. Is it probably toast since it has had air in it for so long? I was going to get it charged up for use this summer.<!-- / message --><!-- sig -->
Old 04-12-2009, 06:48 AM
projectSHO89
projectSHO89 is offline
projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.
Just replace the accumulator/drier as the dessicant has long since saturated.
Pull a hard vacuum on it for at least 30 minutes before charging.
Old 04-21-2009, 09:09 PM
HomerWinzlow's Avatar
HomerWinzlow
HomerWinzlow is offline
HomerWinzlow is gaining momentum as a positive member of FTE.HomerWinzlow is gaining momentum as a positive member of FTE.
Depends largely on how much moisture was trapped in the system over time. If it is rusty in the compressor and if it had an expansion valve they may be toast. Reciever dryer as suggested is definitely out.
Old 04-21-2009, 09:28 PM
dethomson
Thanks guys. I'm no A/C guy...Where's the receiver dryer?
Old 04-21-2009, 09:31 PM
HomerWinzlow
On a 78 F250? Son I havent worked on one of those Dinos for a LOOOOOOONG Time... just follow the high pressure hose from the AC Condenser... it should lead you there..
Old 04-21-2009, 11:47 PM
lsrx101
lsrx101 is offline
lsrx101 has a very good reputation on FTE.lsrx101 has a very good reputation on FTE.lsrx101 has a very good reputation on FTE.
15 years is a long time for a system to be "open".
Much of the interior is raw aluminum which can corrode over time. A good check for corrosion is to disconnect the condenser and blow through it with compressed air. If you see dust blow out, the system will have corrosion issues and closer inspection will be needed. Do the same with the evaporator. You should be disconnecting all of those parts to replace the seals anyway.
The receiver/drier and expansion valve should be replaced, as the other guys have said. Also, change the oil in the compressor if it is the OEM type York unit.
ks4wheeler
1997 - 2003 F150
08-15-2007 04:14 PM
macwilj
07-28-2007 08:26 PM
F250XL
Modular V10 (6.8l)
06-26-2007 12:04 PM
F250XL
1999 to 2016 Super Duty
06-24-2007 03:00 AM
F250XL
Alternative Fuels, Hybrids & Mileage
06-23-2007 10:26 AM
Quick Reply: Is this true?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
