Will not start after it gets operating temp
Old Apr 11, 2009 | 12:54 PM
Raznwlvs's Avatar
Raznwlvs
90 F-250 351w 4x4 (149,000 miles) will not start after it gets at operating temp..It turns over really slow if turns over any...Bought new stater and coil...battery is fine.. wrapped starter to keep it from getting hot and put a shield in between starter and exhauts...Going to store to get rotor and cap now..also think I'm going to get capacitor thats off from the coil...looks like it never been changed..
dunno what else it can be..
Old Apr 11, 2009 | 01:01 PM
88n94's Avatar
88n94
Check the ignition timing with a timing light with the spout connector unhooked. If you can't find the specs try 10 degrees before top dead center.
Old Apr 11, 2009 | 01:09 PM
Raznwlvs's Avatar
Raznwlvs
timming is good already checked that...sorry I didnt post that for ya..thxs
Old Apr 11, 2009 | 01:53 PM
Lazy K's Avatar
Lazy K
Check both battery wires for signs of burning or corrosion under the insulation at the ends and make sure the grounds are tight.
I would also think about checking the fuel pressure. Do you smell any gas in the engine oil?
Old Apr 11, 2009 | 03:28 PM
subford's Avatar
subford
This turns out to be the ECT sensor a lot of the times. It will not cause it to turn over slow but will stop one from starting when warm.
Old Apr 11, 2009 | 03:40 PM
fkaster01's Avatar
fkaster01
ive heard that about the ect sensor before... didn't they used to pour ice water on them then try to start the engine to see if that was the problem?
Old Apr 11, 2009 | 04:02 PM
subford's Avatar
subford
If the ETC sensor says always cold poring cold water on them will not help.
Old Apr 11, 2009 | 04:47 PM
Raznwlvs's Avatar
Raznwlvs
the ground wire has some corrosion on it and will fix that..
no gas smell in my oil..
Old Apr 11, 2009 | 04:49 PM
Raznwlvs's Avatar
Raznwlvs
if the ect sensor was bad it wouldnt start cold or hot correct??
Starts fine after 10 to 15mins..
Old Apr 11, 2009 | 04:56 PM
subford's Avatar
subford
If the sensor always say it is cold the engine will start OK cold but not when it is hot.
Old Apr 11, 2009 | 04:59 PM
Raznwlvs's Avatar
Raznwlvs
sounds good to me and will try a new one then
Old Apr 11, 2009 | 05:21 PM
phoneman91's Avatar
phoneman91
Write us back and let us know what finally fixes the problem.
Old Apr 14, 2009 | 05:50 PM
EPNCSU2006's Avatar
EPNCSU2006
I had the same problem several years ago when my battery was getting weak. You can test this by using jumper cables when you experience the slow turn condition. If the starter spins faster and your battery is several years old, it may be time for a new one.
Old Apr 14, 2009 | 05:55 PM
Raznwlvs's Avatar
Raznwlvs
thxs its not the battery tried another one and same thing..Will let u guys know tomorrow after I put ETC sensor in ..Been working or would have been back sooner..
Old Apr 14, 2009 | 05:56 PM
dustybumpers's Avatar
dustybumpers
do a load test on the battery. clean battery terminals, and check your cables for corrosion inside the jacket .my bet is on the battery.
