99 F-350 SC door panel removal
door panel removal
On my 2002 goes like this. 1.) pop power window/door lock control panel up and disconnect wiring harnesses. 2.) with cover off you can acesss one screw holding panel to door, 3.) pop off reflector/light cover at bottom of door. 4.) with relector off you can access second screw. 5.) pop off small cover just above panel (mirror). 6.) lift up on panel and it should come right off. 7.) pop out light from panel (#3 above).
Here is pictures to fix the door actuators with directions to remove the door panels.
https://www.ford-trucks.com/user_gal...&albumid=12198
Door Panel
Thanks a million, I probably would have tried to pull it off towards me, thinking it had clips like the old school doors. I will do some investigating tomorrow. When i go over bumps... it sounds like the door is going to fall off and there is a squeak in the locking mechanism, the locking mechanism squeaks when i open and close the door. It is not loose and does not raddle when i swing it back and forth sternly. Let me know if anyone has any thoughts. I am sure I will figure it out once I get a look inside. Thank you again!.
mitch199077
Ford Truck Parts for Sale
07-03-2016 02:02 PM
