charging problem f-100 1977 302
I have a f-100 302 1977 with a charging problem. I replaced the altantor, nothing, replaced the voltage reg, nothing. I took the altantor back out and took it to the auto parts store and it checked out fine. I put it back in still nothing. So I have a new altantor, and new voltage reg. and am not getting a charge to the battery. Any help out there. Thanks Jeff
What do you mean by "rang out"?
You'll likely need to test it with a multimeter, a fusible link can look great, but in fact be blown.
If the fusible is ok, the alternator is new and the Voltage regulator is new you need to start tracing wires for breaks. The system is fairly simple and it's all contained right there by the battery area.
Does you horn work? The same wiring harness that contains the connector for the horn also contains the "I" exciter for the alternator.
Skyline Drive
02-08-2015 07:14 PM
kyle78f150
35
03-23-2014 01:45 PM
mattcad
40
07-17-2013 11:02 AM
ffm455
09-27-2009 07:12 PM
