Brake controller
Old Apr 10, 2009 | 07:32 AM
arhuranna's Avatar
arhuranna
Brake controller
Hello,
I have a 2001 XLT 4x4 that I need to add a brake controller to. Does the Excursion have a socket for a plug and use set up? if so where is it located? Any recomendations on a brand? I have been looking at the Prodigy P3. Thanks for the help.
Mitch
Old Apr 10, 2009 | 07:39 AM
cbradford's Avatar
cbradford
Yes, remove the panel under the steering wheel exposing the fuse box and the connector should be on the right side just behind the dash.
Old Apr 10, 2009 | 07:55 AM
bigdaddymedic2000's Avatar
bigdaddymedic2000
from the others who have a brake controller the prodigy is the top of the line. there is a pig tail that i had to buy. and the port is behind the cover under the steering wheel and i had to go through an opening towards the passengers side the connect the plug. it's in an area under the radio.
Old Apr 10, 2009 | 08:30 AM
gr8scott72's Avatar
gr8scott72
Originally Posted by arhuranna
Hello,
Mitch
Just stick your head under the dash and you'll see the connector.
Yes, Prodigy is the way to go.
Old Apr 10, 2009 | 08:54 AM
soutthpaw's Avatar
soutthpaw
You will need to buy the adaptor pigtail plug so you can plug right into the connector... the wire colors are an industry standard on the pigtail, Blue, Black, White and Red
Old Apr 10, 2009 | 06:25 PM
Stewart_H's Avatar
Stewart_H
Many moons ago, I asked the same question. Aklim (Andrew) responded with the same info that's been posted here. I asked Andrew to take a pic for me because I couldn't find my plug.
Here is the picture Andrew took for me:
I was able to sift through the harness in that area and found the plug hidden from view.
That is looking towards the radio/climate control area, from the drivers side door.
Stewart
PS - I have the Prodigy and love it.
Old Apr 10, 2009 | 06:47 PM
KMUL's Avatar
KMUL
I just installed one myself using the pics on this thread. It's a simple job.
Here's some more threads on the topic:
https://www.ford-trucks.com/forums/2...g-harness.html
https://www.ford-trucks.com/forums/3...nder-dash.html
Happy Towing!
Old Apr 10, 2009 | 09:12 PM
arhuranna's Avatar
arhuranna
Thanks for all the help. I am ordering tomorrow.
Mitch
perryg114
Oct 24, 2016 12:28 PM
scraprat
All Things Towing
Jan 4, 2015 09:16 AM
1spitfire
2009 - 2014 F150
Aug 8, 2012 02:44 PM
pepperonipizza
6.4L Power Stroke Diesel
Apr 1, 2007 11:37 AM
lfs727
Dec 7, 2002 12:55 PM
