Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Another newbie!
Old 03-08-2002, 06:11 PM
struckbylightning's Avatar
struckbylightning
struckbylightning is offline
Another newbie!
Hello fellow lightning owners! I am thinking about purchasing a lightning and i was looking for as much feedback as i can get> I am looking for advice ,tips,and many ideas. I want to become a proud lightning owner! thanks in advance.
Brad
Old 03-08-2002, 09:01 PM
true blue's Avatar
true blue
true blue is offline
Another newbie!
I have a gen 1 lightning and love it! It is great to beat most things stop light to stop light. The newer (99-2003) are much faster stock. The first Lightnings (93-95)came with a 351 windsor. The motor came with special GT40 heads and GT40 intake. The pistons are a special 8.8 to 1 compression using hyperutetic (-10 pts for spelling) pistons. It came with dual exhaust and 4.10 gear ratio. The rear end is even a special casting with cooling fins in it. The driveshaft is a light weight aluminum. The transmission is slightly different as well. using the heavy E4OD with some different parts inside for strength.
The new Lightnings use the 5.4 Triton with a supercharger. Again special pistons,exhaust,Transmission, and in later modles a low ratio rear end.
No mater how you look at it, you will be an owner of a rare vehicle that hauls, HAULS, and looks great!
Old 03-09-2002, 03:18 PM
struckbylightning
Another newbie!
thanks true blue. I am looking at a 99 right now and i am just absolutly falling in love with it. what mods have you done to yours? and also what mods have you heard that make the most difference?
thanks
Brad
Old 03-09-2002, 10:47 PM
Lightning Rod's Avatar
Lightning Rod
Lightning Rod is offline
Another newbie!
While I have not done any performance modifications to my '01 (yet), all the information I've read suggests that a high flow air filtration system and a matching chip is a good start. You can expect a 28 - 35 HP increase for about $350.
I've ordered a FactoryTech valve body for the 4R100 as my first mod. I'm just waiting for it to arrive. I also purchased a SuperDuty 4x4 pan that holds an extra quart and has a drain plug in it. It's my understanding that the FactoryTech valve body will correct the somewhat sluggish shifts that the factory settings produce.
RUNVS?
Old 03-10-2002, 12:12 AM
Lightning Rod
Another newbie!
bill6302
03-20-2007 04:58 PM
BroncoBoss351
12-27-2006 03:13 PM
79_custom
17
07-18-2003 01:28 PM
92flaresidextracab
04-06-2002 08:39 AM
bigredtruck
10-22-2001 08:33 AM
Quick Reply: Another newbie!
