D44 Power lock
The following is a description of the 2 units in question. I copied the info from a web site long ago for future reference. Wish I could remember where so I could give credit.
Trac-Lok (T/L)
Built by Dana Spicer for use in Spicer rearends, AMC rearends, and 1998 & older 10.25" Ford rearends. The old design built up until about 1989 was weak. The 1990 and newer design is fairly strong and even rivals the Power-Lok for impact durability, but the clutches do not provide as much lock-up force and tend to wear out in about 50,000 miles if used in the rear. Works better in the front of vehicles because it's not aggressive. The main selling points for this design are the fact that clutch chatter is almost non-existent, and it is very inexpensive. These two points make it a great unit for many applications and a very good value for the money. This unit makes a great front limited slip and works well for those who need a little extra traction but cannot tolerate clutch chatter. The Trac-Lok came factory installed in many models such as D28, D44, D60, AMC 20, AMC35, 10.25" Ford. The problem with this unit is that it is not very aggressive and power transfer is minimal. Also, 1988 and earlier units tend to break fairly easily. (1piece case, 2 pinion gears, and 2 tab clutches). (factory )
Powr-Lok (P/L)
This clutch type limited slip is the strongest and most aggressive limited slip differential available from Dana Spicer. It is a clutch type unit using floating cross shafts that ride up on ramps in the case. When power is applied, the shafts ride up the ramps and load the clutches for a positive engagement. A Power-Lok will not lock up 100%, but it is a very durable unit that will hold up fairly well with tall tires. It can be rebuilt, and can be set up smooth or aggressive by changing the clutch design or stacking configuration. Powr-Loks are easily identified by their 2-piece case. They are a very strong unit due to the 4 spider gear design that provides twice as many teeth to carry the load as a 2 spider gear unit does. However, the case bolts can stretch or loosen after severe use over time. Almost as expensive as a Detroit Locker to buy new. Available for Dana 25, 27, 30, 44 (all spline types), 60 (all spline types) and 70. This was an original IH option.
(4 pin, 4 tab clutches) (factory)
Lee
