i put gas in my truck... need quick help
laugh if you want but today is one of the dumbest day of my life. i put 10 gallons of regular unleaded at the gas pump today. thank god i caught my mistake and DID NOT start up my tuck. it had a half tank of diesel in it before i filled up. my truck is a 2000 PSD super cab short bed. is there anything i can do besides dropping my tank in their parkinglot? i live 400 miles away
thanks
andy
thanks
andy
Disconnect fuel line after fuel pump, add a piece of hose to your pump outlet, run a jumper wire to the positive battery post, and pump the fuel out of the tank and into some 5 gallon cans. after you think you have romved all the mixed fuel put 10 gallons of diesel in the tank and pump that through also. Yes, it will take awhile, but it beats dropping the tank in a parking lot.
EDIT: crap I just realized yours is OBS, see post above mine
ok i got it! thanks for all your help everyone.. i went to wallmart and but a whole bunch of gas cans and a pretty cool little dand pump with hoses included for 8 bucks. i was able to get 22 gallons out the first time. then i put 5 gallons of diesel in and pumped it back out. then filled it up! i put 8 ounces of 2 stroke oil i had in my truck box and its running like a champ. my egt's are normal, it dosnt make any new noise ect.. so far so good. ill feel alot better when i get some diesel clean and a few more tanks of DIESEL through it. this was definately the first and last time i will make this mistake.
You could pit on a drain line from your filter bowl and open the bowl drain, turn on the switch and it will pump it out. The gas goes to the bottom for some reason and will drain out first.
I did this a few years back cause stupid bp has a green gas pump and a black diesel. it still runs on gas but not recommended. It won't explode or anything, maybe even clean your injectors!!
