Play in real axle...
With all do due respect they "stopped" the 9'' in 83, because that is when the 8.8 debuted, but I've heard of trucks until 1990 having a 9'' factory
Back to the RABS, my 87 and 88 both "have" RABS but neither have the VSS.
I do love Ford's ability to clean out the parts bins. I believe its one of the reasons Ford and the other two are having problems making profits because they really don't build rigs cost effectively anymore.
Some early models had the RABS sensor at the transmission.
**EDIT**
Upon further investigating I **think** I am wrong.
A speed sensor (-vs- an abs sensor) can be located on the transmission.
I don't know if you could have a abs sensor anywhere BUT the rear axle???
Last edited by McLeod; 04-08-2009 at 12:58 PM. Reason: correct an earlier statement
On the RABS how did they work it in a truck without a VSS? A VSS is very important to the function of an ABS system.
That's just what I was wondering, do you know how it worked? Changing to that setup could be a good option for those with a VSS in the axle, who want to go with a 9"
OK I will be going with a 9" then. I can get one from the wrecking yard for about 150 bucks. What are some things to look for on the 9" to tell if its good or not? I would hate to get one home from the junkyard to find out it's a steaming pile of *****. The Bronco is an Eddie Bauer, and it has RABS, but it doesn't work. I hope it will last another week, cuz I am broke until then! Thanks for all of the replies!
In looking, of course gear ratio comes first, do you know how to find this?
Second is condition, there's not much that goes wrong with a 9. Grab the yoke and give it a turn, is it smooth? Turn it back and forth, is there alot of play? There should be some, but not more then a couple degrees. Find a way to stop or have a friend hold one axle, while you turn the other. Same kind of thing turn it, is it smooth? You may find at this point a posi, that would be cool. And again turn it back and forth is there some play there should be some but not more then say 10 degrees.
If all that checks out you should be good, if you want to be real thorough you'll have to take it apart. Pulling the axles and then the 3rd member. You'll want to do this eventually to change the oil so you might as well before you buy it.
To pull the axles you gotta unbolt the backing plate. Then give the axle a good yank, a slide hammer or peice of chain is usefull here(bolt chain to lug and whip the it, works well). Then you can unbolt the 3rd member and pry it out of the housing.
This is the only downside of most 9" axles, you gotta go this far to drain the oil. But now you can inspect the gears and count the axle splines, should be 31 but some are 28.
Good hunting.
