towing
Old Mar 9, 2001 | 01:33 PM
samson's Avatar
samson
towing
Hello i just bought a boat. the boat and trailer weigh 3200 pounds together.. now i have a 1996 ford ranger extended cab 2 wheel drive 3.0 v6 5 speed manual transmission.. i have tested to see if the truck will pull this and it did okay.. it struggled a little on hills... so im i okay with towing this much, are am i over my limit... i have been told by other sources that i should be able to pull between 3000 and 4000..... thanks, please give me some info at ajordan1@kscable.com
Old Mar 9, 2001 | 06:30 PM
Jimjdb1's Avatar
Jimjdb1
towing
Samson;
WELCOME TO THE BEST SITE AROUND.
You should be ok towing BUT I'm not so sure about the ramps. You may have a hard time getting the boat out of the water.
Jim.
2000 F-250 XLT SUPERCAB 7.3 PSD 4X4 AUTO, LIGHTED VISOR, ROLL TOP COVER, BLACK AND BEAUTIFUL. I JUST LOVE A FORD TRUCK.
Old Mar 9, 2001 | 06:49 PM
samson's Avatar
samson
towing
Thanks jim, i am confident to that the ranger will perform, i am going to get a receiving hitch put on in the morning and i will be ready for the lake as soon as the weather get warmer..
Old Mar 9, 2001 | 07:53 PM
mefsh's Avatar
mefsh
towing
Not sure about you towing that much. I had a 1994 Ranger ext cab 2 wd with a 4.0 v6 and I was handling my load alright also which was a 18 ft Champion with 150 hp motor dual console. After about 3 hours of towing I noticed smoke coming from under the truck and found out I was blowing transmission fluid out of front seal. I did have a transmission cooler also , one of the biggest made. With that manual transmission, I expect you are going to be changing a few clutches.
Old Mar 11, 2001 | 07:47 AM
Jimjdb1's Avatar
Jimjdb1
towing
mefsh, samson,
I don't think there will be a problem with the towing end of it as I said earlier, I'm a little worried about the power for the ramps. I used to pull a 21 ft 5-er with my 4.0 auto ranger and it was tough but it would pull it at 70mph on the freeway. (Just ask the State Boy that gave me a ticket for it.) The boat should be no problem, just watch the ramps.
Jim.
Old Mar 11, 2001 | 08:38 AM
samson's Avatar
samson
towing
>mefsh, samson,
>end of it as I
>pull a 21 ft 5-er
>it would pull it at
>ramps.
>Jim.
>I JUST LOVE A FORD
>TRUCK.
Old Mar 12, 2001 | 10:57 PM
elliott's Avatar
elliott
towing
quiacato
2009 - 2014 F150
33
Jul 23, 2013 10:03 PM
ah1988
Jul 2, 2012 09:52 PM
Diesel-N-Bucket
May 20, 2011 11:51 PM
deshet1980
1978 - 1996 Big Bronco
Nov 25, 2009 07:54 PM
Goldenboy
47
Aug 14, 2007 07:04 PM
