My 1978 Bronco project
#46
I'm testing a stock length one, but I think it may be a hair too long, so I will probably end up shortening it. I have to account for spring wrap under hard acceleration, which brings the pinion up higher, as well as the normal flex of the springs, so I have to make sure there's room for compression on the driveshaft.
#48
I thought about some type of traction bars to control spring wrap, that would certainly make the ujoints last longer. Especially since I enjoy launching the truck from an occasional stop light.
I'm just not sure if traction bars can be set up so that they don't interfere with the suspension travel.
Not weighed yet, but the title says 4000 lbs. Assuming that's dry weight, and considering the Cummins added 200-250 lbs, operating weight might be up around 4600-4800 now.
#49
#50
#52
#54
How is it for power? I seem to remember you are changing the turbo or somthing. Does that mean you are not satisfied? It would seem that it would have plenty. Of course your other toy (Mustang) is hard to compaer with. How does it compare with a stock Bronco? I've always heard that a Deisel needs more gears than a gas engine. (because of limited rpms) Are you happy with the C6?
#55
With the Cummins running bone stock, (other than advancing the injector pump timing by 1/8 inch) my Bronco with the 35" tires, 3.50 gearing and C6 auto was noticeably quicker than my (ex)wife's bone stock '96 351 Bronco with 3.55 gearing and E4OD.
The C6 shifts into 3rd gear at 26 mph, and since there's no kick down rod, even if I stand on the throttle, it will stay in 3rd. The stock Cummins had so much torque, it would accelerate quicker than the 351 without downshifting.
It's interesting that you ask about its power, as today I got around to installing the 3200 rpm governor spring(366 part), a Denny T fuel pin, and I turned in the full load fuel screw 3 turns. It required taking apart the injector pump, but not a huge deal. Est. hp is now 250-270, and torque is 650-700 ft/lbs.
Yes, I'm used to driving my mustang, and it's pretty quick, but the Bronco isn't all that much slower now. The power of this truck is ridiculous. It will spin the tires in 1st gear like nothing, shift into 2nd, stand on it, and they spin again, shift into 3rd and they finally hook up, and the truck *really* moves, leaving some black smoke behind.
Rear driveshaft I made from some parts. Also a good spot for performance stickers.
New 3200 rpm governor spring for the Cummins. The truck no longer starts defueling after 60 mph, the way it did when it was stock.
It's making twice the torque of a 351W, and 50 more hp, so you get an idea of the acceleration. I will make some videos of the truck this week.
Next I plan to install an intercooler (from a 7.3 powerstroke), an intake manifold from a heavy truck 5.9L Cummins and a cold air intake tube. That will lower the exhaust temperature enough so I can turn up the fuel a little more.
#57
American Thunder, Good job. I was never a fan of diesel engines especially dodge, but I may change my mind. It looks real good in there. I believe you used a body lift, how good would the fit be in an original like my 79? I'm not able to climb up in those lifted bodys. would the fit be to tight? thanks JIM
#58
I'm sure the Cummins would fit without a body lift, it would just be a lot tighter, especially around the firewall. A 4BT Cummins would be an easier fit than the 6BT.
#59
