77 460 and C-6 5th wheel puller
Well it looks like I will be getting my 460 and C-6 from a fellow list member, better then that I will be getting the whole truck. It is a 77 F250 2x4.
1. What do I need to do to this motor to make it ""pull!!!!""" my 15,000 lb 5th wheel trailer? I mean down low, 70 mph on the interstate, up the mountains etc.. I want my cake and to eat it too.
TIA
William (Tony) Whited
74 F350 Ranger XLT Super Camper Special 460
77 F150 Custom 460
El Paso TX
Semper Fi
TIA
77 F150 Custom 460
El Paso TX
Semper Fi
William, I always thought the 390 in my old '70 was a strong puller with 3.50 gears. But last summer I got a '78 F150 supercab with a 460. I couldn't beleive how much more power the 460 has! I need to change my gears, though. I've only got 2.75's. I think 3.50's or 3.73's would be ideal for what I tow. For what you're towing, I thing mabye a good 4bbl setup, duals, and 4.10's or 4.56's would be fine. Don't forget, with today's gas prices, dual tanks and a fat wallet is also needed. :-)
Jason Kendrick
1970 F100 Custom 390/C6
1978 F150 Ranger Lariat Supercab 460/C6
Jason Kendrick
on
>truck. It is a 77
>F250 2x4.
>do to this motor to
>I mean down low, 70
>want my cake and to
>eat it too.
>TIA
>Special 460
>77 F150 Custom 460
>El Paso TX
>Semper Fi
If your 5th wheel weight is "15,000 lbs." the Ford owners guide recommends a 4.63 gear (up to 16,000 lb. trailer).
I tow a 9,000 lb. car trailer and was not happy till I added headers, dual exhaust, RV cam, K&N Filter. I still slow down to 50 MPH on the long steep grades with my 3:55 gearing.
Since you'll be towing an additional 6,000 lbs. I can only see about 4 possibilities:
1. Put in the 4:63-5:13 gears and add an after market overdrive ($2,600 plus/minus).
2. Supercharge ($3,000 plus/minus)
3. Trade your truck in for a Turbo-Diesel...I'm not a diesel lover but very heavy loads and steep grades is where they make up for their steep initial cost (diesel option $5,000 plus/minus).
4. Trade down to a lighter trailer/5th wheel.
Deen Hylton
Ford F250 460 C-6, K&N, Headers, Dual Exh.,Comp. Cams,Shift Kit
Pioneer CD w/Bose Speakers.
Other Passion: Blown 77 Corvette (Sorry Guys/Gals)
How I can afford to Drive the above: 93 GEO Metro
>truck. It is a 77
>F250 2x4.
>do to this motor to
>I mean down low, 70
>want my cake and to
>eat it too.
>TIA
>Special 460
>77 F150 Custom 460
>El Paso TX
>Semper Fi
Deen Hylton
The latest Hot Rod mag has an article on a 57 Merc station wagon. The guy put in a 460 (8.2 compression ratio) with two turbos out of T-Bird super coups (junkyard). It says he has $3000 in the motor, gets 10-12 mpg with 3-1 r&p, and get this, 355 HP and ****714 lb ft torque**** at 2200rpm!!!! Talk about a puller!! That could almost ****** a Powerstroke in half!!
Anyone have a couple turbos they want to get rid of?!
Nathan
Nathan
4x4slik
05-09-2016 08:51 AM
gschembs
09-11-2013 11:33 AM
4x41977
01-18-2008 07:44 PM
f10074
03-20-2001 08:28 PM
Fordzzzz77
04-10-2000 06:11 AM
