Massachusetts Chapter Join Chapter, Leader: donjamer
April MA BS Thread - Keep it Flowing
Old Apr 29, 2009 | 07:04 PM
  #1651
Aerocell4x4's Avatar
Aerocell4x4
Diesel Van Enthusiast
I moved mine around regularly, but certainly not daily.
True I was still wired in, so I could just as well have relocated a PC.
The thought goes through my mind to mount the keyboard and a monitor to the lap-desk and run the leads down to the PC along side my comfy club chair or the couch.
Old Apr 29, 2009 | 07:06 PM
  #1652
donjamer's Avatar
donjamer
Originally Posted by 7.3 Rocket
While laptops are nice and everything a desktop is better for performance on the cheap.
You can continually upgrade a desktop for a reasonable amount of money with relative ease. A laptop's components are more expensive and harder to replace. (From what I've been told. Never had my laptop ripped open)
I can see the reasoning though.
Laptops need more compact components and more compact = more expensive. And any time you cram a large amount of stuff in a small amount of space working on stuff in that space will get difficult.
Another thing about higher performance laptops is that they get HOT.
Not warm. They get HOT. The laptop I'm using now is decent still and was considered high performance when I got it 2 or 3 years ago. It gets extremely hot. I have to keep it on the table with the back elevated for airflow or else it will either burn me or begin overheating.
And I know that if you guys are like me and have Tim Taylor Syndrome (More power!) you will want to upgrade your machine as it gets older. (like we upgrade our trucks)
I really regret having gotten a laptop instead of a desktop. If you don't need a laptop go with a desktop. JMHO
You got it right Pete..
The manufacturers love people to buy laptops cause they know they will need to be repaired or replaced sooner than a desktop..
Old Apr 29, 2009 | 07:08 PM
  #1653
Aerocell4x4
Ya Pete:
My laptop came with three cooling fans, and thus I couldn't just set it on the rug or the couch.
Over the years it softened the adhesive for the covering of the lap desk and the surface blistered. Eventually I peeled that surfacing off.
Old Apr 29, 2009 | 07:09 PM
  #1654
Aerocell4x4
okie
What's the max length for a modern monitor's video cable?
Ditto for the keyboard USB cable?
Can I add an extension?
Old Apr 29, 2009 | 07:10 PM
  #1655
fire240's Avatar
fire240
I am not sure on that Dave. Don might now.
Old Apr 29, 2009 | 07:12 PM
  #1656
Aerocell4x4
I'm hoping that I can USB the keyboard into the monitor.
That would then leave me with just a video lead and a power cord for the monitor.
Old Apr 29, 2009 | 07:14 PM
  #1657
fire240's Avatar
fire240
My old monitor had a built in usb hub Dave. I had to have a seperate usb connection for that to work.
Old Apr 29, 2009 | 07:15 PM
  #1658
donjamer's Avatar
donjamer
Originally Posted by Aerocell4x4
okie
Not sure about the monitor cable length I would have to look that up, but USB cable length max is 16 feet..
Old Apr 29, 2009 | 07:16 PM
  #1659
7.3 Rocket's Avatar
7.3 Rocket
If I'm not mistaken that would be an HDMI cable and I am looking at them on NewEgg.
Longest one I've found thus far is 75 feet for 92 dollars and change.
Now that is cable length. I had help designing the rig I specified. I don't know if you'd need any special anything to get the signal to travel that far.
Newegg.com - BYTECC 75 ft. Cable Model HDMI-75 - Cables
You can get USB extensions in 16' lengths if you want them. Ten to fifteen dollars per 16' extension.
Old Apr 29, 2009 | 07:18 PM
  #1660
donjamer's Avatar
donjamer
Pete, 75 ft for 80.00 at Monoprice.
HDMI Cable
Old Apr 29, 2009 | 07:20 PM
  #1661
Aerocell4x4
I'm thinking like the PC is under an end table vacuuming up the dust bunnies
And I have sufficient cabling to set the monitor / keyboard setup on the coffee table.
16 feet is more than ample, though I would not want to daisy chain any of the cables.
  #1662
donjamer's Avatar
donjamer
Dave, they have VGA/SVGA cables with 100' length..
Old Apr 29, 2009 | 07:22 PM
  #1663
Aerocell4x4
Don:
In the 'old days' there were video tuner PCI cards.
Now with the flat panel TV's that connect to computers and the roll out of digital broadcasting, what's the current scheme?
Old Apr 29, 2009 | 07:24 PM
  #1664
7.3 Rocket's Avatar
7.3 Rocket
You sure? The site Don posted has a 100 foot cable. You could put the computer in the basement and it could be like a space heater down there.
And the USB extensions are rated for up to 5 in succession. That'll put you at 80 feet of reach.
  #1665
donjamer's Avatar
donjamer
Don:
They still have them Dave.. They have Hi-Def ones also..
