I plan on doing the CCV mod along with others while I'm there.
My question is should I clean all the inter cooler lines while I'm there ? CXan the inter cooler be flushed or cleaned ?
I've read a lot of post of oil bing in the lines etc and am just trying to head off any possible problems ..
Is there a link or info on cleaning these ? Especially the inter cooler ?
And while I'm here is the a certain way to flush the steering pump ?
Thanks
No need to clean the IC tubes really. To clean the cooler itself, remove and fill with a water/simple green solution. Let sit for a while, dump it out and dry it out as best you can before reinstalling it.
Would you post that link, I've been in able to find anything using the search feature for the last couple of weeks. Thank you.
Mark- try this: using Google, type in "power steering flush site:ford-trucks.com/forums/" I don't have time to run the search right now but you should get some good results that way.
