302 truck build
#31
#33
The '84 302 (whats left of it) with the newer, or h.o firing order, is in an 84 Crown Vic that had 60,000+ original miles. It belonged to an elderly lady that owned the car since new. Still had new car smell. She lost the title, so I got it for $200 and made a dirt track car out of it. The engine had never been apart. Every nut and bolt was pristine. I have a cousine that works in the parts department at the local Ford dealership, that told me it's very possible that some of the H.O cams made it into the regular engines.
#34
well i ripped apart the other 302 and i have all the the stuff i need to make one 302 now, i just have to put the parts together, its like a big jigsaw puzel.
the one thing i dont have is a carb intake after looking around i might be able to get one cheep but its a square bore and i have a spread bore carb, will the carb fit on it or will i need a adapter? also will a transfer case that came of a standard trany fit on a auto 4wd trany or a 2wd?
pics
i think that frame is from a high boy it has a divorced transfer case
pics
#35
If you arent worried about running egr, the Elelbrock Performer 2121 is a good one. I picked up a new one for $175 at Oreilly's. The Performer with egr, 3723will run you well over $200. You can also get an Edelbrock 600 cfm for around $250-$275 depending on where you shop. The spread bore you have is most likely for a big block and would prove troublesome. I personally prefere the Edelbrock carbs, because they are easy to tune, rebuild, they have mechanical secondaries, and will get you decent gas milage.
#36
#41
i found a few other carbs tucked away in a corner a holly 4v, 2 q-jets and 4, 2v ford carbs(mostly disasembled). would the mottomaster carb that supposedly came from a big block be to much for the little 302? i think this it the intake im going to go with Summit SUM-226030 - Summit Racing Street & Strip® Stage 1 Intake Manifolds
the holly i found is a liitle dusty but a carb kit would fix it up. i looked all over the carb but i didnt find anything that would tell me how big it was, ill take some more pictures tomorrow maby some on here can clear up some questions.
#45
