Whats it take to run a 7' Meyer snow plow?
I might be trading for a 7' Meyer snow plow for my truck. Just wondering what kinda hardware it takes to run it?
Its got the big bracket with the lights, and what looks like an electric motor that says "Electro Tough" on it, the blade itself has at least 2 hydraulic rams that I can see. Pictures are on my phone and cant see very good.
Generally, for a plow to work well, you need a 130 amp alternator (give or take), dual batteries, and a 3/4-ton or better front suspension and axle in good shape.
Usually people buy the plow with the appropriate mount for their truck. The plow comes off quickly with a couple pins, but the mount stays put.
Jason
Jason
The point of the heavier-duty alternator and dual batteries is that typically plowing is done at lower engine speeds for longer periods of time. The hydraulic pump motor (along with the extra lights, etc.) eventually overwhelms the alternator and starts draining the battery. The second battery (hooked in parallel, so it's 12V) gives you extra reserve capacity while the higher-output alternator won't burn itself out trying to charge two batteries.
When it comes to higher-output alternators, I suppose the internet is your friend.
Jason
Jason
I run a 7.5 meyer i used a stock alt for a while but eventually upgraded to a 3g 130 amp out of a mustang search 3g and you wiill see. as for the mount i fabbed one out of the old mount from a jeep took a little work but well worth it when you see the price for a new mount good luck
would u have ne pics of your mount, im trying the same thing on my 96 F150
05 CO King Ranch
1999 to 2016 Super Duty
12-01-2019 09:01 AM
PA74F250
12-06-2015 08:33 AM
Country_boy_2007
11-18-2011 11:46 AM
firefytr29wfd
07-02-2007 10:22 PM
