2001 F-350 Parking Brake Backing Plate
#61
I am curious, has anyone has contacted Ford about this? My rear right caliper completely disintegrated. After removing the wheel and rotor the whole e-brake assembly fell out in a bunch of rusted pieces. The e-brake has been used only twice on my truck in six years. This is extremely frustrating to say the least. It is sad when you jump on the forum and see so many other people having the same problem.
#62
#63
#65
parking brake assembly
Just replaced mine on a 05 F250! Pins rusted out letting brakes shoes flopp around. What was the cost for me?...... was the front end of my truck when the brake failed and hit a light pole in my own driveway $4300 of damage.
Parts dept at local Ford " WE ALWAYS HAVE THEM IN STOCK"
I now know why!!!!!
Redd
I now know why!!!!!
Redd
#66
I now know why!!!!!
Redd
I now know why!!!!!
Redd
I never use my ebrake, but i got an auto tranny.... u got stick shift?
sorry to hear about that
#67
Replacement Backing Plates
For those who may be looking for replacements, I found that Doorman makes some. WWW.doormanproducts.com Take a look at P/N's 924-212 and 924-215. Unfortunatly, they will not fit my '99 F350 but they may help one of you. I purchased the 924-212 kit from United Auto Parts for about $50 and it is for both sides. The left fit my truck but the right will not. Looks like I am headed to the dealer for the right. The quoted $400 for the dust shield with the shoes attached. YIKES!
Good luck,
Jeff
Good luck,
Jeff
#68
Good luck,
Jeff
Good luck,
Jeff
Hi jeff... it looks like those are it, but it says left or right... why did it not fit your 99?
Kenny
#69
My 99 was actually manufactured in March of 98. It seems mine is an odd-ball. I have since modified the one that did not fit bu cutting and welding. I couldn't see spending an additional $400 when we have all the other parts and might only get another year out of this truck. This truck is a crew cab that gets used daily in our construction business.
#70
Awesome man thanks for those part numbers... for 100 bux I think I might try it. Found it at rock auto...
RockAuto Auto Parts just look up the number by part number
Ken
#71
1999-2004 Ford F350 Super Duty Brake Backing Plate - Brake - Replacement, Rear Left, Rear Right 99-04 F350 Super Duty Brake Backing Plate - 5365-06008081 - PartsGeek
Will these work? I'm having the same problem with mine. One is hanging on by a thread just so I can pass inspection.
#72
So I'm changing calipers and rotors on my truck and find that the backing plates are rotted. None of the local stores have the parts (NAPA and CarQuest). So I go to the dealer (I hate going to the dealer, they rip you off). So the parts guy tells me that they are part of an assembly that comes with the caliper bracket, 4 studs, and all of the parking brake parts for $335 each side. Of course the assembly doesn't include the rubber boot where the cable attaches. Is this true? Can anyone direct me to a place to just get the backing plates? Any other suggestions?
#74
#75
