Tranny cooling question??
Old Mar 27, 2009 | 08:56 PM
Baja16's Avatar
Baja16
i've a 96' F-250 with a 351W and a E40D tranny, i just replaced the motor and since it was out i decided to replace the trans lines going from the tranny to the cooler on the grill and radiator. I had 1/4" hydraulic lines made up to replace them with. I noticed afer i got them the fittings on the end of the hoses are a little bit smaller than 1/4'' and may resrict flow. Will this extra rescrition hurt anything on the tranny and will it make a big differance on how hot the tranny runs. I plan on making a trip from NY to WI haulin a 900lb boat and i dont want to worry over heatin the tranny
Old Mar 28, 2009 | 04:24 PM
master_mechanic's Avatar
master_mechanic
that depends on how restricted it is... if its just a little bit i wouldnt worry but if it was like half the size of the line i would be concerned
Old Mar 28, 2009 | 05:13 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Restrictions will reduce the flow, which reduces cooling and reduces the lube flow to the trans. I can't say if it's enough to make it a problem or not.
Old Mar 29, 2009 | 05:44 PM
Baja16's Avatar
Baja16
well the actaul line it self is 1/4'' the same as the original... the fittings on the end of each line are smaller, not half but close maybe 5/32'' never measured then before i put then on...
