Engine Bearing Help
Engine Bearing Help
Hello,
I am replacing the bearings in a 390 and have a question about the bearing set. Where do the large bearings with the flange on them go? On the front bearing area or in the middle bearing area of the block and main cap?
Also, I noticed the bearings on the block, the oil holes don't line up. They seem to cover about 1/4 edge of the hole on the two front of the center and the one rear of the center. I noticed the oil holes in the bearings are centered and the oil holes on the block are off center. Do I have the right year of bearings for this engine?
Thank You
Thank You
Ya, the thrust goes in the center main.
Ya, the oil holes NEVER line up. For a stocker, that's fine(it made it 40 yrs already). For better oiling, match the holes up. Some do the bearings, some do the block. Some also say doing the block weakens the block/cap area. It also takes a good cleaning to get the metal shavings out(usually have cam bearings out). For simplicity, carefully take a dremel and dress the bearing oil hole til it matches the block. DO NOT NICK THE BEARING SURFACE!!!!!! Work it from the back side, go easy, take your time. Make sure to use some fine emery/crokus cloth to remove any burrs.
The following users liked this post:
2) B8A6337A .. Thrust Main Bearing (#3)
Fits: 1958/60 332/352.
8) C1AE6333A .. Numbers 1-2-4-5 Main Bearings
2) C1AE6337A .. Thrust Main Bearing (#3)
Fits: 1961/63 352/390/406/427.
8) C4TZ6333H .. Numbers 1-2-4-5 Main Bearings
Fits: 1964/76 352/360/390/410/428.
** 2) C4TZ6337H .. Thrust Bearing (#3)
Fits: 1964/65 352/390.
2) C6TZ6337J .. Thrust Bearing (#3)
Fits: 1966/76 352/360/390/410/428.
