firewall
03-27-2009, 11:17 AM
firewall
i need to know the easiest way to bypass the firewall for a power wire for an amp. thanks to any help............
03-27-2009, 11:21 AM
There should be rubber plugs located in the corners of the cab i ran my cb coax through one of them havent had a leakage problem yet
03-27-2009, 11:27 AM
Quote:
Originally Posted by
darthice
where? top? bottom? left? right?
03-27-2009, 01:18 PM
you could run it through the boot where the steering passes through the firewall or drill a hole and put a gromett there
03-27-2009, 01:26 PM
on
There's lots of space where the wiring harness comes through the cab/firewall (just behind pedals) and it's an easy to access space from the cab and the engine bay. Get a rubber grommet and drill away.
03-27-2009, 05:00 PM
1966Tbird
but wouldnt that have the chance of getting hung up on the steering?
03-27-2009, 05:07 PM
nflfreak43
Not if you can find a way to keep it away from the steering.
03-27-2009, 05:12 PM
fordtruckman80
wait duh! i just remembered when the steering column goes through the firewall it has a little shield. so nvm. idk why i forgot bout that.
