My Overdrive light is flashing on and off, and the truck is shifting really hard..Ive read that this means the tranny is in limp mode? Or the tranny is overheating? i really do not want to have to replace this tranny until i can afford a whole swap. Can anyone confirm the problem here? much help appreciated. The truck is a 96 F150 351W ext cab shortbed, and its a 2wd.
also ever since i got the truck..(about 6 months) if you put it into drive it lurches forward or if its in reverse it will lurch back, along with a clunking noise. or if your slowing down to a stop, it will do the same thing, even if youre on the brakes.
For this problem there is a thread on the transmissions page about that. The transmission expert there described a faulty valve I think. If you scroll down there you could read it.
As for the other shifting problem you should pull the stored codes otherwise it is only guess work.
