Gally Plugs
Old Mar 25, 2009 | 07:40 AM
Blackwaterforge's Avatar
Blackwaterforge
Gally Plugs
Brass or Steel?
Old Mar 25, 2009 | 02:33 PM
camperspecial65's Avatar
camperspecial65
If you are referring to water jacket freeze plugs on the engine...go brass...I had steel in my FE...they didnt last too long... and having them replaced in the truck wasnt cheap...easier to go brass while engines out IMO.....plus Fords are known for their heavily rusted cooling systems usually from neglect..go brass :-)
- cs65
Old Mar 25, 2009 | 02:46 PM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
Blackwaterforge
If you are talking (OIL GALLY) I would go steel and a good sealer, the old ones have to be
heated to remove them so they don't break off and then have to be drilled to remove.
If you are meaning freeze plugs? Then BRASS for sure!
Wally Womack
Old Mar 25, 2009 | 04:04 PM
Blackwaterforge
Yes.Freeze plugs. Thank you for your reply!
Old Mar 25, 2009 | 06:36 PM
Pro-Street/StateTK
Blackwaterforge
A trick that I always use is " apply a thin film of (RTV) around the freeze plug before installing ". It always works great!
Wally Womack
Old Mar 26, 2009 | 08:09 AM
spurredon's Avatar
spurredon
I always put a little "Indian Head", on them.
Old Mar 26, 2009 | 08:17 AM
Blackwaterforge
Thanks for the tip! I am going to install brass (Freeze) plugs this Saturday while the engine is out. Engine is a 300 six from a parts truck (65). Last Saturday we seperated the engine and transmission and found it had a new clutch,pressure plate and throw out bearing. When they replaced the clutch they didn't turn the starter ring around? We are replacing the pilot bushing with a pilot bearing and the rear main seal since the bellhousing had some oil in it. We stem cleaned the transmission. It is a Borge/Warner T-18 . The previous owner had filled it with transmission fluid? Hope to have engine and transmission bock together and in the truck within the next couple of weeks.
Thanks agian for all y'alls help!
Old Mar 26, 2009 | 09:23 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The early 1965 240 & 300 flywheel ring gears had 184 teeth.
If this is what you have, and cannot find a replacement, Ford replaced the 184 tooth gear with a 164 tooth gear midyear 1965.
C5AZ6384D .. Flywheel Ring Gear / Still available from Ford.
MSRP: $64.03 // FTEpartsguy.com price: $46.10.
Old Mar 26, 2009 | 12:50 PM
Blackwaterforge
Thanks ND!
I will count mine. It dosn't appear to have been turned around. What is the plug on the block behind the flywheel?
Old Mar 26, 2009 | 04:00 PM
NumberDummy
C5AZ6266A .. Plug, Camshaft Rear Bearing
Old Mar 26, 2009 | 04:22 PM
Blackwaterforge
Thank You!
Old Mar 27, 2009 | 07:32 AM
Blackwaterforge
Freeze plug kit came with 7 plugs (5) 1 9/16 Brass, (1) 2 1/16 Brass and (1) 2 5/16 Steel. There are 8 plugs in engine 5 in side of head that are
1 9/16 and one at the back of the head 2 1/16. Two in block one is 2 1/16 and the other is 2 5/16. I hate to sound stupid but do I need to buy another 2 1/16 plug?
Thank You!
