adrenaline installed! and the rest of the story
#107
Rick, I went with Bill at PHP because Bob said "let me make a phone call on a Sunday" he called in a favor for me. and I really appreciated it. I did email Jody on Sunday to ask it there was a HPOP cap or something that would limit the 550 pressures. I recieved an email yesturday from Jody basicly saying, that I had a pump or injector problem not a tuning problem.
I appologize to everyone. Sorry I got my panties in twist earlier. Its been a long week and I guess I just took it all wrong. its all good. Barney
#108
Buhl, Filer, Hansen, Kimberly, Eden, Hazelton, Jerome, Wendle, Gooding???
I used to live just northwest of Jerome before moving to Montana. Didn't mind it so much down there. Still have alot of friends in that area and need to get back down to visit. What took you down there?
Sorry for the .
Sorry for the .
#109
#110
#111
Strokerace, I'm in Wendell right now. grew up in Burley and have family all aound here.
What do i do? I used to be the local Snap on man. then I retired and went rving. The economy has had me trapped up here for the last 2 1/2 yrs so I've been lead tech for a former customer. funny thing stopped by on the way south from Alaska and haven't left yet. I think I have a job down around Atlanta lined up so I hope to back on the road soon. Been in one place too long. Barney
#113
All of you mechanical gauge guys need to remember one thing, who cares what a mechanical gauge sees? If the PCM does not see it, it cannot be used.
What does this mean? Well, I'm no expert, but tunes and a PCM run truck rely on sensors. So what those sensors tell the PCM is what you have to work with. I don't care if you can make 3800psi ICP, if the PCM does not see it properly, you are floundering around. That's my 0.02c.
IOWs, datalogging is a fair measure of what the PCM is seeing. If that is off, a fix is in order.
#114
OK!!! some good news!! I just went down and topped off the fuel tanks. I had topped off the tanks the same day I installed the new HPOP. the previous tank was 265 miles of daily driving and short 20 mile trips to town, and six 10 mile loops down the freeway going from 60 -90mph over and over to get data before the Adrenaline install. 10.4 MPG
This last trip meter was 365 miles. same daily drives. one 160 mile trip up over the mountain 2300 ft to 6000 in a snow storm, and 12 WOT test runs to data log the New HPOP numbers. 11.7 MPG
Thats a big jump. I know its not what the rest of you guys get, but you gotta remember my truck weighs 11,000 lbs.
I think an initial increase of 1.3 MPG is pretty awsome.
Thanks for waiting. Barney
#115
After reading much of this thread, there seems to be a lot of misconceptions.
Bfife your pump isn't holding pressure, for one reason or another (pump problem or an issue elsewhere). One thing that cannot be blamed is ICP tuning. Regardless of whether the truck is an F-250, F-350, or F-550, and regardless of the tuner (Jody, Bill, whoever), the pump isn't maintaining the pressure that you need. If you were to look at tuning tables for Jody or Bill's programs, you would see that the ICP demanded isn't quite what you think it might be. Try something closer to stock levels, and you'll be on the right track.
For some reason there is this idea floating around (and I've recently seen this on another forum too) that tuners are asking for insanely high ICP programming in their tunes. That is not the case. If the F-550 PCM is calling for 2750 psi of ICP at WOT, then Jody's, Bill's, and everyone else's tuning is going to call for that pressure too, or something close to it. However, yours is dropping down to around 2000 psi in higher HP settings. Why? Because of the additional fueling called on by the chip. The tuning is still calling for the same oil pressures, but at an increased fueling level which is what's putting a higher demand out for oil volume. Can't blame Bill or Jody for the drop in pressure here. It's the hardware that can't keep up.
That's why you still see a huge drop in oil pressure even with Bill's tunes. Going from a low of 1950 psi in Jody's tuning to 2050 psi in Bill's tuning is a drop in the bucket. If anything, they are very very close in numbers. A 100 psi gain that only gives you just over 2000 psi of oil pressure is nothing to be happy about. There is something wrong...... somewhere.
As for a manual HPOP gauge (that was mentioned earlier).... don't need it. The ICP sensor is actually very accurate. Hook up any manual gauge, and you'll see very similar numbers every time. In fact, some gauges don't register the rapid changes in pressure as fast as the ICP sensor can. In those cases, the sensor is more accurate than a gauge.
#116
Pocket, I have read you discussion on the other site. Very Very informative. I understand pumps don't make pressure they make volume. its the restrictions(injectors, IPRs etc) that create the pressure. And I agree, there is something else going on with my truck. I should be seeing bigger numbers. What do you think it might be and how would you reccommend I test for it. I thought about geting some injector orings but I just don't have the time before I have to leave. Barney
#117
Then there is always the pump. It's brand new and there may be some lingering issues that Bob was unable to foresee. Or maybe you got a defective one I've seen posts on other forums with the same pump, and seen a much greater increase in ICP over a bone stock HPOP. So to me, something is going on. Bob's pump is not supposed to be a direct stock replacement, yet the results you got indicate nothing more than stock performance at this point.
Again, I'm not blaming the pump entirely as the problem, it could be elsewhere. It's just not going to be an easy solution at this point. That's the joy (or curse) of being one of the early guys buying a new product.
#118
I would ask for one favor from everyone.....please ease up on the new guy a bit. It doesn't take much digging to figure out that this guy: https://www.ford-trucks.com/forums/member.php?u=503928 is this guy:https://www.dieselsite.com/adrenaline/BryanA.html Being that he's been running this pump for two months I'm inclined to take him at his word. All he's really said is that he's happy with it....and if my truck responds the same way his did you can bet your booty that I'll be doing the happy dance out in the street.
