Where to Buy Main Oil Seals?
Old 03-24-2009, 04:13 PM
Douglas DC-9's Avatar
Douglas DC-9
Douglas DC-9 is offline
Douglas DC-9 is starting off with a positive reputation.
Question Where to Buy Main Oil Seals?
I am looking for a front & rear main oil seal for a 2000 7.3L diesel. Just wondering where I can get the seal from other then a dealer. Are there any "aftermarket" sellers of the seals? Any makers of them that are known to holdup better then others?
Thanks
DC-9-32
Old 03-24-2009, 04:26 PM
Ponyboychris's Avatar
Ponyboychris
Ponyboychris is offline
Hit it!
Ponyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud of
I would try an international dealer. In the past with gassers, I've used Felpro and other similar brands but I don't have a clue if they are good for our engines.
Old 03-24-2009, 04:28 PM
bdrummonds's Avatar
bdrummonds
bdrummonds is offline
bdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud of
Main seals rarely go bad on a 7.3. If you are seeing a little bit of oil leaking off the back of the motor, then it is probably from the CCV issue in your other thread. it may also be the oring s on the HPOP.
I have only heard of main seals going truely out once, and it was in an abused, neglected truck, that the motor ended up being dusted.
miller_feed's Avatar
miller_feed
miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
This guy has the best prices on OEM parts. click here
EDIT: Brandon, I think he has the motor out of the truck and is changing things because of this. I think.
Old 03-24-2009, 04:41 PM
Douglas DC-9
Yeah.... I'm replacing every seal and o-ring while I have it out to do the oil pan. Glow plugs, injectors a waterpump, as well as fuel lines will also be replaced.
I think I might even paint the engine International blue too!
Thanks Again!
Dan
Old 03-24-2009, 04:53 PM
Ponyboychris
Hit it!
Just curious but can't you find a master gasket kit that has the stuff you need? Or did you and you don't like the looks of some of the stuff in it?
Old 03-24-2009, 10:25 PM
Douglas DC-9
haven't looked too hard for one, I looked at a "main oil seal kit" off some link on google and they were asking +500.00 for it... I figured the seals can't be that much. But then again.... we are talking about Ford parts here.......
abe
05-19-2016 10:33 AM
bpimm
12-22-2015 05:45 PM
gtex
07-29-2004 05:30 PM
drew222
03-05-2004 09:50 PM
Ice 9
11-08-2003 05:58 PM
Quick Reply: Where to Buy Main Oil Seals?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
