1963 390 engine swap to 1976 360
This is probably a better question to ask in the FE forum. The difference in motors mounts is a well-known thing there.
I'm going to hazard a guess and say that the motor mount holes on the 1963 390 will NOT be in the same spot as the '76 360.
Not sure what you can do about it. I've heard that swapping motor mounts from side to side makes up the difference, but not sure if that's a real solution.
smokey6309028
04-24-2007 01:22 PM
Fordman7780
10-01-2002 09:21 AM
