89 ford radio doesnt get constant 12v
On my 89 ford f350, I am in the process of installing a stock oem radio in it. however, I am not getting constant 12v from the light green/yellow wire like it should according to the wiring diagram. It gets 12v on the acc. wire when the key is turned and the ground wire is connected, and the radio definitely works. How does this wire come off the battery?
I actually worded that worng. the light green/ yellow wire that is supposed to get 12v all the time never gets power. The yellow/black wire, on the other hand, gets power when the key is turned like its supposed to. If I went the route of running a wire from the battery for it, what amp fuse should I use?
A 10 or 20A fuse should be plenty fine. This fuse is there to protect the wire not the components, so you need enough fuse to power the radio, and blow if the wire is shorted to ground.
Because it never has power, I'd suspect you have a blown fuse. Don't trust the eyeball method, fuses can blow but look okay. Break out the DMM and check them all.
ckleine
10-09-2014 01:27 PM
strokin'_tatsch
19
12-10-2011 02:50 AM
