2003 f350 4wd 7.3 ps
03-20-2009, 07:57 PM
on
I know have a 1987 F350 6.9 banks 6.9 and am looking at a 2003 F350 PS 4WD that is going to be at auction. It is fully loaded, 108000 miles. What kind of problems do I need to look for? It is an automatic. What should it be worth? I live in Knoxville, Tn. any oppions?
03-20-2009, 08:06 PM
on
blowby, leaks in the valley, pinion seals, balljoints, pull the intake tubing and check the turbo for dusting. Not shure if you can do all of that at an auction though. Price depends on condition though. I wouldn't give over 13,000 myself.
03-20-2009, 08:09 PM
Really depends on cab design.Standard is pretty cheap,extended a little more,and crew the highest price
03-20-2009, 08:17 PM
about 13,500. I would look mostly for blow by and oil leaks
03-20-2009, 08:21 PM
on
Sorry, it's a crew cad, leather, has no tail gate? Looks good, didn't appear to smoke when 1st started, I didn't get chance to look for blow by(through oil fill right?)
03-21-2009, 09:53 AM
on
If it is a duelly , six new tires are under 1k, new rear brakes are 600 or so. Front brakes a little cheaper . ball joints and hubs about a 1000 also. Knowing you have the last of the best....priceless !
03-21-2009, 11:16 AM
You can get all that maintance down cheaper if you try. Start the truck up look for any leaks, get a flash light and look into the valley and see what kind of leaks you have, if you can pull the intake tube off the turbo and look at the wheel and check for play. What auction is it at I might go down and look at it with you.
03-21-2009, 12:40 PM
on
I have a truck thats at the same mileage, still has org. brakes its all in the way you take care of it. There should be nothing wrong at all with it.
03-21-2009, 01:35 PM
on
Well, the truck brought 13500 and then add 10%. It was nice, but out of my price range to not have a PPI done. Thanks to all for info!!
bly8397
Tennessee Chapter
03-18-2013 08:15 PM
Richard2212
1999 to 2016 Super Duty
02-06-2011 09:19 PM
TennesseeMustangPerf
Tennessee Chapter
02-26-2010 10:09 PM
jdecker88
20
01-24-2010 05:11 PM
HareBall
Tennessee Chapter
10-24-2007 07:01 PM
