Rough idle and stalls while driving
Old 05-30-2016, 06:41 PM
Delonge2002's Avatar
Delonge2002
Delonge2002 is offline
Hello all,
I have a 2004 ford ranger edge 3.0 V6 that has given me and a few mechanics the same issue. It idles rough and occasionally stalls while driving. I have replaced the MAF, idle air contoller, fuel relay, and fuel pump. Issue still exists, my next replacement item is the crank angle sensor, but I am not sure what it does. Is there anything else to consider?
Old 05-30-2016, 08:08 PM
spooktn's Avatar
spooktn
spooktn is offline
Temporarily Deactivated
I would scan it with a scantool if you dont have one autozone will scan it for free ,,,,and just guessing it could be throttle position sensor ,,, but scan it and post codes dont just throw parts at it
Old 05-30-2016, 09:34 PM
Delonge2002
I already had it scanned at AZ, nothing hit, battery was putting out good voltage and alternator was the same, no CEL is showing. I cleaned the MAF and replaced the TPS, it worked for a little then the MAF failed and I replaced it. Took it to a shop and they found a burnt relay for the fuel pump, which was replaced. The truck ran fine for a month then the issue came back, so the fuel pump got replaced,thinking it was a fuel problem. Just drove it for three days and it stalled out again. I'm beginning to the think that there might be a problem with the the fuel injectors or ignition coil.
Old 05-31-2016, 05:32 AM
tomw's Avatar
tomw
tomw is offline
The bad fuel pump might have taken out the relay, possibly by using more amperage and eating the relay points. Try a new relay.
tom
Old 06-08-2016, 01:00 PM
Delonge2002
Saw some damage to the coil pack and replaced it, engine sounded good on start up but quickly stalled during a 5 min drive. Mechanic took a look and checked the inertia switch, tested bad and had it replaced. So far it hasn't stalled, but the RPMs sometimes drop when the vehicle has stopped. This usually happened prior to the stall. Waiting to see if the inertia switch was the problem.
THE BLUE HEAP
06-30-2011 10:28 AM
freckler
01-03-2011 09:02 AM
Sheryle
09-25-2009 06:01 PM
1998Ranger25L153CID
04-08-2008 10:43 PM
karlg
01-04-2005 08:57 AM
Quick Reply: Rough idle and stalls while driving
