No OBD II signal?
No OBD II signal?
My son in-law went for his emissions test. The attendant told him that he wasn't getting any readings from his OBD II. We both thought it was a fuse. We looked in the manual and can't find any that seem to be the right one.
Any pointers as to how to figure it out would be appreciated.
It is a 05 F-150 5.4.
Thanks for any help.
David
David
A couple of years ago I had a similar problem getting my emission test. They said the machines couldn't read some of the newer Fords. I tried two different stations before I took it to the dealer, where they did the test. There was a software update to the testing machines to correct this problem. I have since used these other places without any problems. This may or may not help you, but it 's something to look at. Good luck.
I agree with what BillC is mentioning... as my mother's '05 Taurus does the same with my OBDII Actron; but when I use my Snap-On diagnostic tool it reads the codes and other telemetry just fine.
Also, the guy at the local Advance Auto also has a hand-held *newer* Actron that will read her car too.
Thanks for the replies. I just had my 05 checked a couple weeks ago. No problems, thank goodness.
Enomra
6.7L Power Stroke Diesel
06-10-2016 06:41 PM
msaylor
10-02-2013 11:58 AM
santacruzf250
07-01-2007 08:40 PM
