New Jersey Chapter Join Chapter Leader: sddesigns
Window Tint in NJ
Old 08-20-2008, 07:40 PM
sddesigns's Avatar
sddesigns
sddesigns is offline
Window Tint in NJ
Does anyone have window tint on the front driver and passenger windows? I just purchased a 2001 Excursion 3 weeks ago from PA and I'm waiting for my plates and registration, once I get them it's off to inspection. The front windows have a light 30% tint and I'm debating just taking it off before inspection or should I chance it and fail, then I'll have to make another trip to inspection.
Old 08-20-2008, 07:59 PM
NJF350SD's Avatar
NJF350SD
NJF350SD is offline
Hi Steve,
If memory serves me correct 30% is too dark for the front windows. If it were me, I'd probably go for it and try it before yo go through the effort of taking off the tint, expecially if it was professionally installed.
Or you can find a "freindly" station that does inspections and they may look the other way...
-Chris
Are you going to the Randolph inspection.
Old 08-20-2008, 08:08 PM
sddesigns's Avatar
sddesigns
Yes, any advise?
Old 08-20-2008, 08:36 PM
NJF350SD's Avatar
NJF350SD
NJF350SD is offline
Not really other than as you know the place is huge you get in and out pretty quick.
Old 08-20-2008, 08:59 PM
frederic's Avatar
frederic
frederic is offline
You can have a private inspection done by a service station for about $80, and generally speaking they are by far less **** than a state-run facility. You can also "take a chance" since it's summer and bring the vehicle to the state facility with the windows completely down. It's statistically likely that they won't power them up to test them, and to be sure you can always pocket the power window fuse for the 15 minutes it takes to go through...
But even with a valid inspection sticker, you're not allowed more than 15% tint on the front windows unless it's "factory", and any cop in the mood to torture you can and will do so if you're pulled over. Some cops even have a device they clamp onto the edge of the door glass and it measures opacity fairly precisely - and ticket accordingly. Again, if pulled over just slam both front windows down and hope the cop is after a seat belt ticket or a burnt out taillight.
Old 08-20-2008, 09:11 PM
73f100shortbed's Avatar
73f100shortbed
73f100shortbed is offline
No window tint allowed. Don't remove window fuse. they check if they work most of the time.
Old 08-20-2008, 09:23 PM
NJF350SD's Avatar
NJF350SD
NJF350SD is offline
That's what I thought too, but wasn't 100% sure and didn't want to mis-speak.
Old 08-20-2008, 09:36 PM
sddesigns's Avatar
sddesigns
I also checked NJMVC (No Tint on Front Windshield or front side windows) and tintcenter.com/laws/nj, same.
It just looks so good....maybe I'll try a local private inspection first and deal with the consequences if they'll overlook it. Other wise it's peel peel peel.
Old 08-22-2008, 07:18 AM
frederic's Avatar
frederic
frederic is offline
I rememberd 15% being legal, so I looked it up:
HOW DARK CAN WINDOW TINT BE IN NEW JERSEY?
Darkness of tint is measured by Visible Light Transmission percentage (VLT%). In New Jersey, this percentage refers to percentage of visible light allowed in through the combination of film and the window.
Windshield No tint is allowed on the windshield.
Front Side Windows No tint can be applied legally to this window.
Back Side Windows Any darkness can be used.
Rear Window Any darkness can be used.
HOW REFLECTIVE CAN THE TINT BE IN NEW JERSEY?
Similar to sunglass lenses, some tinting film contain metallic elements that help in reflecting incoming light and reducing the glare and heat generated by visible light.
Front Side Windows No metallic or mirrored appearance.
Back Side Windows No metallic or mirrored appearance.
OTHER NEW JERSEY RULES AND REGULATIONS
Restricted Colors No colors of tint are explicitly banned.
Side Mirrors Dual side mirrors are required if back window is tinted.
Certificate Requirements Manufacturers of film do NOT need to certify the film they sell in the state.
Sticker Requirements No sticker to identify legal tinting is required.
Medical Exemption State allows medical exemptions for special tint. For more details about the specific terms of the exemption, consult your state law.
This was from a window tinting manufacturer, paraphrasing NJ law. Seemingly I was wrong - no tint on the front windows - period.
Regarding the "fuse trick", I've NEVER had a problem doing this. Does that mean I won't experience a problem next time? Who knows. But I personally NEVER had a problem doing this, and other minute clever things to avoid inspection failure.
Privacy facilities are worth the $80 however, depending on the kindness of the shop.
Old 08-22-2008, 02:35 PM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,078 Likes on 2,148 Posts
well, if you drive an ex police car with tinted windows, the inspection people will pass it.
but you did not hear that from me.
Old 08-22-2008, 08:14 PM
NJF350SD's Avatar
NJF350SD
NJF350SD is offline
hear what...?
Old 08-23-2008, 08:22 AM
tjc transport
i ain't rite
hear what...?
that Santa got busted last year for being a window licker?
Old 08-23-2008, 07:42 PM
NJF350SD's Avatar
NJF350SD
NJF350SD is offline
Originally Posted by tjc transport
...Santa...a window licker?
Ya know. I think I'm just going to let this one go. This one can go so MANY different places and none of them are any good...
Oh, by the way
Old 09-18-2008, 08:00 AM
thetiler's Avatar
thetiler
thetiler is offline
I need to take mine through Inspection this month
I am probally just going to remove the tint
Jason
Old 09-20-2008, 09:32 PM
sddesigns's Avatar
sddesigns
Great private inspection garage, look ma an inspection sticker (see gallery)......
Quick Reply: Window Tint in NJ
