Started in on my cab corners today...
#61
#63
#65
One # is for the 2# spool, the other for the 11# spool You most likely want the 8" spool used by most of the smaller machines, but check your machine before ordering. Make sure you have or else pick up a package of .025 tips for your stinger while you are there.
#66
At any ESAB welding supply dealer. ESAB is not as big an advertised brand as Lincoln or others, more industrial focus, so even their dealers tend to be low key. Give your local welding supply place a call and ask if they carry ESAB.
Here's the link to the catalog item:
Spoolarc Easy Grind
They also have a dealer finder function there.
The 2# spool is an 8" spool size that fits most machines.
Spoolarc Easy Grind
#67
I saw where one guy was using the MIG wire as filler fot TIG work on thin metal. Have you tried this easy grind for TIG filler?
#69
Hi AX,
Sorry 'bout that, I just assumed you did have one. I feel sort of guilty considering the fact that I bought my Lincoln TIG-225 almost a year ago and I have yet to really use it for anything than a regular stick welder because it has that capability. Other than firing it up and playing with the TIG part just to see if it works that has been the extent of it. I like using a TIG for aluminum but I have never used one for stuff like thin body metal. I did some research on that. What I mentioned to you I now remember seeing in a book I bought about sheet metal fabrication. The guy was using MIG wire as a filler.
The thing I find most awkward about the TIG is that you need to sit down because of the foot pedal control. That is rather hard to do when working on some areas of a vehicle body. I think someone makes a variable trigger control that is located on the torch if I remember correctly. I may try to find one of those.
In my defense, part of the reason I haven't used the TIG much is because I have not advanced to that stage of the work on my trucks. However I am getting closer.
Later Man...
Later Man...
#70
Received 4,130 Likes
on
Spoolarc Easy Grind
Spoolarc Easy Grind
John
#71
Dave, the TIG can do anything that stick can do and do it better and neater. My brother's TIG has the torch with the slide switch, it is MUCH better for anything but sitting down welding.
John, Trust me, all wires are NOT equal. Ask your dealer to order you the Easy Grind, it's worth it. You may need to give them ESAB's catalog #.
#72
AX,
I agree with you but you gotta remember that after 50 years of pushing a stick and doing a lot of heavy metal welding that old habits are hard to break. I grab the stick leads with out thinking whem I could be using my MIG-255 which is currently set up 45 wire. It will weld the heaviest stuff. I also have a Lincoln 170 SP with smaller wire in it. So I have no excuses.
I will have to check into the slider switch for my Lincoln TIG-225. I think it would work out for me.
Later Man...
EDIT:
I found a hand control for the TIG-225 $215.00 sounds a bit steep but you know how lincoln prices are. It could be worth it though. Dang !!! Why is there so much stuff out there I think I need???
#74
on
#75
