distributor question
Old Mar 13, 2009 | 07:55 PM
73fordman's Avatar
73fordman
i have a 79f250 anyway the question i have is it is only gettin spark when i crank it ove its got a new control module and and nothin wrong with the harness could it be the magnetic pickup in the distributor is bad?
Old Mar 13, 2009 | 08:08 PM
2classics's Avatar
2classics
Are you absolutly sure on the wiring? It sounds like the hot wire to the coil is only getting power when the staring relay is pulled in.
Old Mar 13, 2009 | 08:14 PM
73fordman's Avatar
73fordman
yea
yea im sure cause it all worked and then i had the key on working on the tail lights and i was told it fried the ignition box or the pickup the red wire on the coil is hot with the key on and the green one used to be but after i had the key on the whole time i think its the pickup
Old Mar 13, 2009 | 08:20 PM
2classics's Avatar
2classics
Take an ohm reading on your ignition coil. You might have fried that. I think it should be around 1ohm.
Old Mar 13, 2009 | 08:25 PM
73fordman's Avatar
73fordman
yea
yea ill try that it could have fried that earlier i took the 2 prong plug off the ignition module and had power to both sides of the coil but as soon as i plugged it back in i lost power to the side with the green wire but still had power to the other one
Old Mar 13, 2009 | 08:38 PM
2classics's Avatar
2classics
leaving the ignition on without the truck running is bad juju for electrical system.
RadioControlGuy85
Mar 9, 2014 02:19 PM
restoringmy46
Nov 28, 2011 10:15 PM
Ratt617
Nov 11, 2010 09:01 AM
darrin1999
Mar 1, 2008 10:59 PM
64fordf100292
Mar 16, 2007 04:11 PM
